JVC AV32F577 In last 6 months we've been received this message "USB Over Current Error. Please push OK button after you remove USB Devise" dozens of times a day. JVC in Wayne, NJ......clueless. I have NOTHING but my satellite box connected to this tv. Any ideas?
  • 3 more comments
  • bruce207 Jun 28, 2008
    Same problem with JVC, model # AV27F577 using Comcast, not satellite... also use Comcast for Internet, nothing else hooked up to TV... occurs dozens of times per day
  • Anonymous Jan 18, 2009
    I have a JVC tv with the same error. A couple years ago I had the problem after connecting it to a dlink digital media center. Eventually I gave up and took them apart.
    This year I have an xbox using XBMC playing videos to the tv, and i've started to get the error message.
  • bearsin Jan 18, 2009
    I have a JVC tv (not flatscreen) with the same error. A couple years ago I had the problem after connecting it to a dlink digital media center. Eventually I gave up and took them apart.
    I have a few things hooked up to it. I have an rca switch box to switch between a dvd player, the Wii, the xbox.
  • JDawgg29 May 14, 2009
    I called JVC and the guy couldnt find an answer... this is CLEARLY a JVC glitch and not a satellite or cable box problem... its not a coincidence that all these tv's were issued in 2006 and the same 27f557 or 32f577 models... JVC will produce a program or a recall if they get enough compliants!!! AGAIN, call JVC and lets get this **** fixed!!!
  • 286 Answers
Does it look like the error is coming from the satellite box or the TV?
You may have to disconnect the box and run the TV using its internal tuner, or by plugging a DVD player or VCR into it to test run it for a while.
If the TV runs for a day without the error message showing up, your satellite box is the culprit. Check prices, it might be cheaper to replace than to repair.
Posted on May 07, 2008
I have a Nikon Coolpix 7900 camera I purchased used. It came without the proper USB cord, so I purchased one separately. When I attached the camera to the USB port of my computer (and I've tried...
I'm afraid that USB port has been damaged and is drawing excessive current causing the error message. You are at least fortunate in that your computers' ports are protected since the camera could have otherwise caused damage. Using a basic multimeter one could probably measure across the pins 1 & 4 to determine if the camera's input is shorted; it should in no case measure less than 5-6 Ohms regardless of lead polarity. The current capability of a USB port varies by version but is between 500 & 900 Milliamperes.
Sep 23, 2011 | Nikon Coolpix 3200 Digital Camera
My USB port power error message
This happens when anything draws over 500mA, of current, if it was working OK, before, and is working now but displays that message, or not working, well in any case it seems to have gone faulty, and somehow, is now drawing more current drain, the USB port can supply. It may have been spiked too.from all the plug/unplug especially if the safely remove hardware is not used.
May 06, 2010 | Dell Latitude C610 Notebook
Error code- print system failure code 0xc18a0501
Solution posted here is straight off the HP support site and didn't work for me. However, elsewhere in this forum is something that did!
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Feb 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
To my disappointment I called Hp and spoke with their technicians for the second time regarding Ink System failure 0xc18a0001? I reset the IDS by pushing the * and # key then hit 123 and I got the message...
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless optical mouse #97990 Rev 5 does not work
Remove the batteries. Remove the receiver from the PC. Reinsert and try to link them again.
Aug 31, 2009 | GE Wireless Optical Mouse
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
I have C7180 All in one
Hi it could work I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
Auto channels
is there MENU KEY press it then enter and install or tunnig option choose it and tune which channel you want
Feb 10, 2008 | JVC AV32F577 32" TV
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
