Question about Apple iPod nano 5th Generation
My ipod will not charge or even switch on - Apple iPod nano 5th Generation
  • 4,323 Answers
Hi
Try and reset the ipod by--
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Hope this helps...
Daniel
Posted on Aug 28, 2010
  • TIER666 Oct 10, 2010
    Dude your freaken crazy!!!!!!!!!!!!!!!!!
    you made my Goddammmmmmmm day!!!
    Your a GURU!!!!!!
  • nicwam1920 Apr 06, 2011
    THANKYOU!!!! this is our 2nd 5th generation due to the same problem. The 1st was returned to Apple and a replacement sent just prior to Xmas 2010. I have saved your instructions just in case it happens again. Having to constantly uninstall and reinstall Itunes is a huge pain in the neck.
Ipod does not power up
Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
To turn the hold switch off, slide it until you no longer see the orange patch. Press any button to turn on iPod. Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod
Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via
USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information. Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost. Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
Disconnect iPod from all power sources and leave it disconnected for about 24 hours. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it. Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod. b>
Mar 24, 2013 | Apple iPod Audio Players & Recorders
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
I have a iPod shuffle 2nd gen. But haven't used for a long time. Now its not switching on. What to do?? :(
Batteries--especially rechargeable ones--do not hold their charge forever. The batteries power naturally drains, even if you don't use them. Just recharge your ipod, and it should work fine.
Dec 16, 2012 | Apple iPod Shuffle Second Gen.1 GB MP3...
My ipod is not yet charged even if i charged for 2 days
ipod batteries have only a certain amount of charges before they need to be replaced
however if you cant remove or replace the battery try wrapping it tight in a piece of newspaper the in watertight plastic bag lets say a plastic sealed sandwitch bage place in the freezer overnight then remove it let it thaw for
2 - 4hrs then charge it
making absolutely sure no moisture gets in to it
hope it helps
Apr 04, 2012 | Apple Audio Players & Recorders
Switching off ipod video 80Gb
The "Do Not Disconnect" message will persist until the the iPod is fully charged. Even after this, the message will still persist - it just does this by default. As long as the spinning wheel in the far upper left-hand corner of your iPod screen no longer appears, the sync has been complete - as soon as it is fully charged, safely remove the hardware on your Windows desktop (or use the Eject button in iTunes - or both), and remove the iPod from your PC.
Mar 23, 2009 | Apple iPod MA446LL/A MP3 Player
IPod nano will not switch off
Does the lock switch still work on top of the nano?
Jan 10, 2009 | Apple iPod nano
My husband bought me a sylvania ipod for Christmas...I can not get it charged...I am wondering if there should be another part that charges it besides just the USB..I am electronically challenged..lol I...
Hi, is the Sylvania ipod play actually an ipod or a mp3.
If it's an mp3 i'm guessing what you would do would be connect it to the computer via USB cable. Switch it on and your computer should hopefully recognize it as a removable disc. If the light on the MP3 player lights up it should be charging. When the light automatically switches off it should be fully charged and ready for use.
At least i think so. I'm basing this on one of my slightly older MP3s, so it might not work, but it's worth a try. Good Luck!
Jan 08, 2009 | Audio Players & Recorders
After plugging in Nike attachment nano wont even switch on
I don't know what the Nikec onnector is or does, but I can help you, if you think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Feb 24, 2008 | Apple iPod nano
Apple ipod
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano 5th Generation Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
