Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
Can the Canopus ADVC-110 be reset
My canopus ADVC-110 seems to be stuck and will not go into capture mode
  • gobojo Nov 27, 2008
    My Canopus ADVC110 is stuck with both Analog and Digital lights ON.  The selection switch does nothing.  I am using an external 6 VDC supply with the correct polarity.
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
Posted on Aug 20, 2008
I had the same problem. My ADVC-110 was stuck with both digital and analog lights on, wouldn't switch to analog mode, and wasn't recognized by three different computers or any software when I was troubleshooting the problem. This was especially frustrating because it had been working OK the day before, and the only thing that had changed was that it had been unplugged to use on another computer, and got stuck as indicated above. Finally I changed the firewire cable I was using, and it worked beautifully; the original cable must have been damaged when it was disconnected. I confirmed this when I tried the original firewire cable on one of my external hard drives - it didn't work on that, either.
Posted on Dec 28, 2008
    Scholar:
  • 119 Answers
Push the Input Select button. If it doesn't stay in Analog Input mode, then either your computer is sending a DV Record command which is putting it back into Digital Input mode, or your ADVC is broken.
Try a simple capture application like WinDV if you're running Windows.
Posted on Aug 11, 2008
My Canopus ADVC-110 has both input light on and I
The problem got no free response so I ordered a new unit.
Jan 02, 2010 | Canopus ADVC-110 (77010150100) Video...
How do I get the video out firewire option to become avilable with my canopus box?
You are found your advc video capture has rear and front cable connector so you can find this very simple.
Nov 28, 2009 | Canopus ADVC-110 (77010150100) Video...
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
No colour..
Sounds like you're feeding the ADVC the wrong broadcast format. Either PAL when the ADVC is in NTSC mode, or NTSC when the ADVC is in PAL mode.
Alternatively, your capture software may have a broadcast format setting as well, and that may not be matching what the ADVC is sending out. Remember that the ADVC does not do NTSC<->PAL format conversion, so NTSC analog input becomes NTSC DV, and PAL analog input becomes PAL DV.
Aug 07, 2008 | Canopus ADVC-110 A/D Converter...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
Problem in Canopus ADVC-110
Maybe different OS? If your friend have XP and you have different operation system?
May 28, 2007 | Canopus ADVC-110 (77010150100) Video...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
1,783 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
Alun Cox
Troy Staley
Troy Staley
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
