Question about Epson Office Equipment & Supplies
Epson stylus photo r240 printer problem I have
Epson stylus photo r240 printer problem I have replaced all 4 ink cartridges with new ones ,but i am still getting error message E-01 on the printer display, i followed the instuctions in the printer manual i even tried uninstalling the printer and drivers from my computer system but this made no differance i still get the E-01 message telling me to replace the ink cartridges anyone got any idea how to get around this problem.
  • 51 Answers
SOURCE: Epson Stylus photo 2100
Highly possible that the "compatable" cartridges are not really compatable or that Epson has updated software or firmware to keep them from working. Try replacing with Epson cartridges or see if the non-OEM brand seller has a resetting device so the printer sees those cartridges as full.
Posted on Dec 29, 2007
Basti
  • 1447 Answers
SOURCE: epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
Posted on Nov 08, 2008
eclark317
  • 159 Answers
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
SOURCE: dont know how to get cartridges out of my epson
Check the board rear the contacts chip or the flat cable. I have the similar problem and the board is moved on the up. Then i push the board down and all the cardriges are recognized.
Posted on Sep 23, 2009
Epson stylus photo rx700 lockout
Look for cartridge sensor and clean them with a piece of close. re-install the cartridge and see if the problem is solved. if not may be U have bad sensor so replace with new ones.
Jun 02, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
How to install new cartridge
Make sure the printer is on and not printing. Have a new cartridge handy, as this installation should be done in one session.
Note if the "cartridge is low" or the "cartridge is empty" light is activated on the printer and follow the specific instructions carefully in the document below for each situation.
See "Removing and Installing Ink Cartridges" in the following document:
Epson Stylus Photo R300 - Removing and Installing Cartridges
Mar 01, 2010 | Epson Stylus Photo R300 InkJet Printer
R 340 cartridges have remaining ink but printer
just go to the process of ink cartridge replacement without actually putting in new ink cartridges, sometimes printers make read errors, just make sure ink cartridges are placed properly to position.
Jan 17, 2010 | Epson Stylus Photo R340 InkJet Printer
I cant remove the cartridges from my epson stylus
Follow How to on epson status monitor for replacing ink tank. Or, turn on printer, immediatelly unplug power while carriage moving. Then move carriage by hand to replacement position.
Nov 08, 2009 | Epson Stylus C86 InkJet Printer
I have a epson photo stylus R240 printer but
Find printer driver at epson website refer to your os.
Oct 20, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo rx580
Hi-
Hope this helps
Nov 08, 2008 | Epson Stylus RX580 InkJet Photo Printer
376 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
