Question about HP Pavilion a705w PC Desktop
I have a hp pavilion desktop and the lightscribe just stopped working 1 it wont read any disc error (520)
  • 9 more comments
  • rasafka Aug 28, 2010
    how do i do that
    it did not work
    I TRIED EVERYTHING YOU SAID BUT IT STILL DON'T WORK . WHAT ABOUT IDE/SATA settings from the BIOS.
    i tried everything you said so far but still not working . but when i go into BIOS there is no setting for IDE not AHCI also browse into AHCI configuration and change it to IDE or disable it.
    as far as the dvd's i only use hp lightscribe dvd-r and they worked until this problem started
    i don't know if it will help but my system is a HP PAVILION e6432f
  • rasafka Aug 29, 2010
    I SENT REPLIES BUT YOU ARE NOT GETTING THEM
    IT DIDNT WORK
    it didnt help
  • rasafka Aug 31, 2010
    the link doesnt tell you how to fix the problem
  • rasafka Sep 02, 2010
    no response from you
  • 4,889 Answers
Disc error means the drive is not able to read the disc. Usually due to a problem with the lens/laser assembly. Did you try using a dvd lens cleaner to see if that solves the problem? Make sure you use a branded one. It brought my DVD writer back from dead many times!
Posted on Sep 03, 2010
Click on the link below to view the forum on how to fix the HP Pavilion Lightscribe disc error
http://www.lightscribe.com/discussionboards/index.aspx?g=posts&t=5284
Posted on Aug 29, 2010
  • HP Master
  • 4,924 Answers
First check if the disk drive icon it is still present in the My computer folder..if it isnt than go to the device manager by right click on my computer ..than properties.../hardware ..device manager ..
In here click on disk drives..and take a look at the device ..if it is in yellow with an ask sign on it , it means that the driver is missing ..for it ...
you can right click on the device ..and choose driver update ..and go with the wizard that starts..but instead of automatically choose manually choose a driver ..(the bottom choice) ..and after that choose from a list ..and when windows displays the list with drivers for dvd writers..get the one that it is most likely ..(the same manufacturer at least )
this will probably bring it back into the drives list in my computer .If the device is not opening the tray ..and no light is lit ...than better open the computer and check the power supply ..and the connection to be ok ...
if the tray pops out ..but the disk is not read..and even after the troubleshooting of the driver it is not getting back ..it is probably been attacked by a virus ..and you will need to reinstall it completely to get it back ...
Lately I had many problems of this nature..with a driver eater..that affects these **** drives...but a complete re-installation with a boot-able installation disk ..and the complete format of the Cdrive ..will get it back ..
If you have a operation system boot-able cd ..to check this issue it is enough to insert it ..and restart to see if it is booting from cd ...if it asks on restart to press any key to boot from cd ..do it ..and let it load a few files..this means that the disk unit is ok ...stop it by restarting ..and take the installation from the start and go for it ..but first save any files that you need from the C drive to other partition ..
if teh boot-able disk is inserted (the one you use for reinstalling the operation system ) ..but it is not asking to press any key to start booting from cd ..than go to bios by pressing F10 on start (immediately ) ..and in there select the boot order...from the advanced panel... and put the first boot device to be the cd ..and second the Hdd..and save changes with F10 ...
this will only kick in when a boot-able disk is inserted..and do not affect the normal boot of the computer ..
In short ..I believe that the computer has been affected by a virus that wiped the disk units driver ...and to be sure it is back ..you have to use a boot-able disk with the installation of teh operating system ..and make a clean install..
if you do not have the drivers for it ..to use after installation ...they are available on these site ..
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=435558#N650
  • 2 more comments
  • Catalin Turcu
    Catalin Turcu Aug 29, 2010
    I never asked ..is the disk drive stopped working or just the light scribe function ??
  • Catalin Turcu
    If the disk drive is nonfunctional but it still eject the tray ..just reinstall the operation system and will work for sure ...I told you ones before..there is a virus that attacks the disk drive driver software ..and by reinstalling the operating system you get rid of it and the driver for the dvd writer is built in windows...
  • rasafka Aug 30, 2010
    just the lightscribe stopped working
  • Catalin Turcu
    Catalin Turcu Sep 03, 2010
    in this case try to reinstall the software that you use for it ...it might be something from the software ..cause usually if it broke it goes off with all functions ..not just that ..so it might be ok ..but to have error from the software or the type of disk you use..
  • HP Master
  • 4,737 Answers
If it was working recently, then should be a problem with the lightscribe software. I hope you still have the lightscribe software (it should be included with the cd that came with the desktop, if you don't have it any longer or can't find it, then click here to download), if so, please uninstall the lightscribe and reinstall it. Not only that, you also need to run a registry cleaning using a Registry Cleaner like CCleaner (click here to download). Download and install the small tools, run the Registry cleaner after the lightscribe is uninstalled. Restart the computer and reinstall the program.
If this doesn't help, let me know. Maybe you need to check the IDE/SATA settings from the BIOS.
Good luck.
Thanks for using FixYa.
Posted on Aug 28, 2010
  • 1 more comment
  • Lebanon Raingam
    Lebanon Raingam Aug 28, 2010
    I want to know whether you are replying my solution or to another experts' solution. If you are replying mine. Please click "Add comment" just below this post. I am confused. Thanks
  • Lebanon Raingam
    If the last reply is to my solution, follow the steps below:
    Shut down your computer, open the case and change the sata port of the DVD writer (connect it on another sata port), now reboot your computer and go into Bios settings (F1 or F2 or Delete, varies from pc to pc) and restore the settings to Default, (you'll see something like "Restore Optimized Default" or similar with "Default...") and press F10 or save the changes and restart your computer, let it boot into normal mode. Now check the Drive. If it's not successful. Restart you computer once again and go to Bios settings, and look for IDE configuration sub menu (should be in the Advanced Menu) and check the settings, if necessary change it to IDE not AHCI also browse into AHCI configuration and change it to IDE or disable it. Now save the settings and boot the system once again.
    It's also necessary try with deferent make of Media (CDs or DVDs), Lightscribe doesn't support all medi type, means all Brands of CDs and DVDs.
    Please response by clicking "Add a Comment" below my posts. Otherwise I'll not consider the reply is mine. It makes me confused whether the reply is for me or for other experts. Thanks.
  • Lebanon Raingam
    I better opt out. I haven't received a reply from your side. If you want me to go with you, please response my post by clicking the "Add a comment" below my first post. Thanks.
  • HP Master
  • 11,800 Answers
That error signals the fact that the chipset can't communicate with the optical unit. Open the desktop and unplug the data cable, reboot, wait 5 minutes and run a registry cleaner - the one in CCleaner will do, shut down the pc, reconnect the data cable and reboot. If even after that the unit still doesn't work then it's dead - replace it.
  • 3 more comments
  • Azrael SRL Aug 28, 2010
    Exactly how i said it: open the desktop (unscrew the 2 safety screws and take out the side panel), pull out the cables from the back of the dvd-writer, reboot and go tohttp://www.ccleaner.com/ to install the program, open the program, click on the registry button and run it, close the pc , reconnect the cables - they go in only in one way so don't force them.
    Leave the setting the way it is - if you mess with it the hard disk will not be recognized and Windows will just not load, the end result being that you will have to reinstall it.
    If even after all of that the writer isn't recognized then it's dead - replace it.
    Sorry but i have to say it again: your dvd-writer has died - the dust has settled on the lens in so large quantities that it has blocked the laser.
    but why can i burn and watch dvd's but just cant do the lightscribe ?
    The lightscribe requires that the laser emits more power than normal - this extra power is absorbed by the dust.
HP a6500f will not come on...no HP Logo...no beeps...black screen...fans run
if u have system mechanic, you can use the disc to boot from and it'll read your MBR....it is probably messed up....and needs to be repaired. Have you ever used a registry cleaner? if not, you also may have tons of registry errors....and registry errors can also give you blk screen of death.if you have no system mechnic disc nor can borrow one, then try this.....http://download.cnet.com/MbrFix/3000-2094_4-10485990.html?tag=mncol;1
please post back you findings
Apr 22, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
When I try to burn a laber I get a message that the lightscribe drive is not recognized (520) the disc chbn@comcast.net
Try reading a disc from it. If that won't work, your drive is dead. Try upgrading your drivers, or upgrading the lightscribe software.
Dec 30, 2010 | HP DVD 740VI 16X16 Dual Layer LightScribe...
My HP Pavilion a1412n doesn't seem to have the lightScribe direct disc labeling software installed...do I need to reinstall the operating system?
No, all you need to do is to reinstall the software.You can find it here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-28739-16&lc=en&dlc=en&cc=us&lang=en&os=228&product=1846452
Sep 29, 2010 | HP Pavilion Media Center a1412n-b PC...
Optiarc DVD RW AD-7201S5 drive does not read lightscribe discs
get a new DVD drive, up grade.
VISTA OR W 7 IT IS.
the problems
HP a6642p (SUPER OLD DESKTOP)
CIRCA 2010.. ?
does device manager show, its OK?
HAVE you gone to HP.com and loaded the drivers for this yet?
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-a6600-desktop-pc-series/3793920/model/3825363
Apr 05, 2017 | HP LightScribe dvd640i (DVD640I)...
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
LightScribe stopped working
its not NEW its , NEW OLD STOCK (NOS)
old lightscribe, drive. the drive that prints labels on top.
NO OS STATED nor any PC stated.. wow.
Lightscribe is mostly not supported now. (read the wiki, on that it dont lie)
obviously and very hard to diagnose.
1-bad drive.
2: bad driver for drive
3: upgrated OS and it dont support this (why post lacking OS)????
4: bad media.
read this.
https://en.wikipedia.org/wiki/LightScribe
then at that bottom read HP unstable.
From HP's official site, they started phasing out Lightscribe drives in HP computers in 2011, due to "industry conditions beyond our control."
windows 8, 8.1 and w10 its not supported.
go to HP.com read what your PC supports, with the unstated
by you PC, and unstated OS
tdk and verbatium stopped making them.
not this is dead now
some get w8 to run with W7 drivers
why not ask at HP. why here?
https://h30434.www3.hp.com/
sure NOS disks are sold rotting on selves... sure.
try google for help? see the words no support?
1st hit
http://www.wikihow.com/Use-LightScribe
Aug 19, 2017 | HP LightScribe dvd640i (DVD640I)...
HP LightScribe 740i dvd burner/ wont read dvds
u try using 80 conducter cable,if u using 40 conducter cable ,
regards prasanna
Mar 03, 2008 | Computers & Internet
Lightscribe
You can get colored blank discs, but the Lightscribe only "prints" in shades of black. You will need to get Lightscribe compatible discs, which are just like "normal" cd's / dvd's with the exception of having a special coating on the one side.
You can visit Lightscribe's website for complete tutorials.
www.lightscribe.com
Feb 25, 2008 | Computers & Internet
HP Pavilion a705w PC Desktop Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
