Question about ViewSonic VX900 19" LCD Monitor
Same problem i have a planar 20" monitor and it worked fine for months, then one day i turned of my computer then rebooted it and the monitor just flashes on for a sec then goes black but the light stays green.
    Genius:
  • ViewSonic Master
  • 1,673 Answers
It may be the back plane lamps, and or the back plane power supply that is in a failing condition. If in your model they are changeable, they should be changed together.
You can verify this by turning on the monitor, feeding it with a known working source, and shine a flashlight in to the screen at an offset angle to your view. If you can see some image in the screen, then you know that the monitor itself is functioning, and the problem is back plane lumination.
Jerry G.
Posted on May 19, 2008
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Mar 18, 2015 | Planar Computers & Internet
Tip
Planar PX2710MW frequency out-of-range
After a computer reboot, about 8 out of 10 times the monitor would display a blue "frequency out of range" message. It would take several power off/on cycles for the monitor to finally display Microsoft Windows.
I called Planar tech support. They were super-nice. After about 15 minutes in which I shared my screen with them, the tech suggested I go into thePX2710MW's main menu (i.e. "Button 1") and then click "memory recall".
Problem solved! Wow.
on Feb 26, 2016 | Planar PX2710MW Monitor
Planar Monitor PL2011M Truns off after 2 secs. Any idea what is the problem ? Thanks Amruth
Navigate to the control panel, click Start then click control panel.
Double click power options.
On the Power Schemes tab ensure that the fields are set to NEVER.
You can however set the monitor to turn off after 20min which I do recommend, to make your computer more energy efficient.
damnor01
Feb 02, 2011 | Planar PL2010M 20" Flat Panel LCD Monitor
Hi My Planar (PL2010M) suddenly went black. On restart, it flashes briefly but never comes on. Any suggestions?
I have a similar problem on my Planar PD470; power supply failed after about a year and a half. I heard that their HDTV power supplies had a higher than normal failure rate. I have someone working with the company to resolve, but I'm not optimistic... Bah Humbug. How long have you had your set?
Nov 09, 2010 | Planar PL2010M 20" Flat Panel LCD Monitor
Configuration menu is stuck up
reboot your system again..and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Resolution problem
A Chip on the monitor circut board must be reflashed. You need to send back to Planar, do an rma. They were very responive to me, sent me a replacement.
Sep 07, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
Backlight replacement
Are you sure it's the backlight? Many Planar LCD monitors have issues with the capacitors on their power supply boards. The symptoms include a power light and no picture, or just a flash of a picture when powering up and then nothing.
The fix for some of these problems is about $8 on new capacitors (Plus shipping).
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3/4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technitian for the work and give them the parts list above. That should work if the failure looks like I described. I've fixed several of these monitors so far. All the problems were related to the power supplies. Same with the Planar PL1700 LCD monitors.
Jan 31, 2008 | Planar PL2010M 20" Flat Panel LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
83 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
