Question about Dishwashers
Dishlex DX 303 SK Dishwasher Manual - Dishwashers
SOURCE: Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Posted on Jun 07, 2009
tinkerbill
  • 12 Answers
SOURCE: Not drying dishes
The fact that it does not work on all three settings suggests it's something common to all three. Sounds like perhaps your immersion heater is bad or even worse, some contacts or relay in the control circuitry of the drying cycle. To check the immersion heater will require you to pull out the washer from under the counter & to remove power from the appliance. Looking underneath the unit, remove a power lead from one side of the heater unit. Next, turn a volt/ohm meter to the highest ohms setting, turn it on, and touch the two leads together to make sure it's working. It should show zero no matter what ohms setting you have selected. Next touch each lead to each of two posts on the heater unit. It should show some resistance other than zero if it is good. If still zero, you will need to get a replacement heater from your fav local appliance store or go on-line and order it. Either way, make sure they have the full identification of your washer make/model. Let me know results?
Posted on Jan 02, 2010
  • 70 Answers
SOURCE: Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Posted on Jan 07, 2010
SOURCE: wanting a maunal for Dishlex 300 global
Try this site. www.appliancehelponline.com Just supply your model or product number.
Hope this helps.
Posted on Jun 07, 2010
SOURCE: I would like to download
I think I have a PDF 300 Manual. Please email at mexeter@westnet.com.au and I will email it back.
Rergards
Mark
Posted on Sep 03, 2010
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Dishlex dx 203 buzzer
solenoids that control water flow (taps) buzz when failing Check out the water in solenoid.
May 26, 2013 | Dishwashers
I would like to download a user manual for dishwasher dishlex global 300 DX 300 WA - thanks Lou
Rergards
Mark
Sep 02, 2010 | Dishwashers
Wanting a maunal for Dishlex 300 global dishwasher. Model DX 300 WA * 01. Thanks
Hope this helps.
Jun 07, 2010 | Electrolux Dishwashers
Intermitten cycle. Stops during cycle and flashes 20/. Motor runs, but no water in and out.\r\nThanks Leah model DX 303 Sk
Check your water flow in the hose pipe. clean the incoming water strainer located on the wash machine body where the water inlet hose is connected.
You can try pouring water up to 10 liters in the wash chamber. Close the door and run .
May 18, 2010 | Dishwashers
check this
Jan 06, 2010 | Electrolux Dishwashers
How do you acces the power switch for replavement
turn of power undo control panel screws remove panel you should see the switch replace and re assemble hope this helps
Nov 13, 2009 | Coffee Makers & Espresso Machines
I have a Studio SK-303 - the zig-zag dial is
Did you find the answer to your question? I have an extra manual for the Studio 303 if that would help you.
Cathy
Jun 14, 2009 | Singer Deluxe Knitting Machine
Apr 11, 2009 | Dishwashers
Dishwashers Logo
424 people viewed this question
Top Dishwashers Experts
Owen Barnes
