Question about Acer AL1912 19" LCD Monitor
How do i remove the back panel of acer screen
  • 11,361 Answers
Acer Aspire 5315 Screen Keep Go Black
Does changing your power options in control panel make any difference?
Dec 18, 2012 | Acer Aspire 3680 Laptop
How do i get the back off my acer aspire 5532
Hi!
Here is a link where you can check the manual for your Acer Aspire 5610. Please click this Acer Aspire 5610.
Hope this can help.
Jul 24, 2011 | Acer Aspire 5610 Notebook
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
My acer travelmate 4650 screen has broken, i bought a 4600 as a replacement with it being the same size screen is it possible to use this or not, the cable and the inverter are different. please help
Most replacement panels do not come with the inverter. If the two LCD panels are the same size and type (ie: xga). You should be able to remove the inverter and use the original from your 4650. A replacement panel should not set you back more then $100.00 if you do not want to trash the 4600.
Please rate this post if it has helped you,
Thanks, Gary
Jul 13, 2010 | Acer Computers & Internet
I accidently uninstalled acer screensaver on my acer aspire laptop and it removed my hibernation mode also i want it back, please
You can right click on any open area of the desktop to get display options. Find the screen saver tab and preview the screen savers until you find the one you lost. Once found apply it and click ok. Then go to start or windows icon in bottom left. Then select control panel wint he windows utility menu. Once there go to performance and maintenance. select power options and adjust acordingly. Good Luck
Nov 22, 2009 | Acer Aspire 5315 Notebook
Acer 5920g screen problems
it is probably a loose or crimped LCD cable, either on the main board or on the back of the LCD panel itself.
Sep 25, 2009 | Acer Aspire 5920-6727 Notebook
Acer travelmate 2410 hinges broke on cover how to remove broken hinges to repair
Very carefully, 1-push the screen right back holing the hinges where tey should be, 2-you have to unclip the black panel (over the power button) using an old credit card so yo dont damage the plastic, as this panel loops over the hinges & can only be removed with the screen right back, BUT remember to be carefull as the cables run through the blak covers & you don't want to snag them!
I've done this before so don't be afraid to pull hard start at the edges & make sure when aclip releases not to carry on pulling (use your thumb on the base of the comuter whilst pulling, dont just rip em off as you'll crack the panel quite easy.
but first I'd see if you can get replacements they're only aluminium angle plates with 2 screws holding them to the base.
Hope tis helps!
Sep 22, 2009 | Acer TravelMate 2300 Notebook
ACER 4315 flickering screen (very bad)
  1. First since it is only 3 months old. Bring it back to where you purchase it so that you can avail of the warranty.
  2. If for any reason you cant do that then try the following
  • Turn off your laptop
  • remove the LCD bezel by removing the rubber and screws
  • try to reinsert the cable that attaches the monitor to the INVERTER. The inverter is the one lighting up the screen. Usually this is located at the bottom of the screen
  • if this doesnt work then try to remove the LCD panel and reinsert the flex cable located at the back and see what happens
NOTE: make sure when you remove cable and re inserting them in, your laptop should not be attached to ac or battery.
i hope i was able to help
Apr 07, 2008 | Acer Aspire 4315 Notebook
Have acer notebook aspire 1410 cant get case appart
remove all visable screws on bottom of pc,remove battery and covers remaining screws are hidden in such places,remove screws at back behind screen to lift front panel and access keyboard removal.depending on model access to panel with mouse pad is done after keyboard lifted.
Mar 08, 2008 | Computers & Internet
Dismantle Acer travelmate 270 Laptop
Caution is advised, as getting everything to work again after you put it back together is normally difficult, especially the screen. You will have to remove all the panels underneath, all screws and look for screws around the screen hinge area, with hexagon heads. There are no instructions on acer notebooks on their site for obvious reasons.
Mar 18, 2007 | Acer TravelMate 270XV Notebook
Acer AL1912 19" LCD Monitor Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
