Refrigerators Logo
Posted on Aug 28, 2010
Thermastat for a centrex ctf 360 need one whats the price $$$$ please
1helpful
Feiya CTF 1501 embroidery machine. How I setup frame for Dahao 129L.
You contact the maker in Japan. This machine is not known to us in North America.
Didn't I find the manual for you yesterday and also the contact details?
Unfortunately no one here knows that machine and neither does Google know very much.
https://www.google.com/search?q=Feiya+CTF+1501+embroidery+machine.+How+I+setup+frame+for+Dahao+129L
2answers
Centrex remote control code
Dear all
I got split centrex air conditioning model CTAR60GW l lost remote. I have new one but I haven’t code number please send me code thank you so much
I have a Centrex T.V and remote but don't knnow how to tune it. Can you please help
Don't know about Centrex, but many flat screens are tuned by entering Menu,'Set Up' , select Auto tune and press Ok
1helpful
2answers
Centrex a/c keeps shutting off every 15 minutes ( split system)
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
2answers
.ctf file and .ptf file
A .ptf file needs to be flashed to the psp's internal memory. You need custom firmware in order to do it and there is a slight chance you can brick the psp.
Psp slim 4.01 M33-2 ctf themes not working.
hey dude.. dis is miguel jalandoni from philippines.. i also had dat problem.. but.. i realized something.. i noticed dat there are different cxmb's and der are specific ctf's for each... maybe ur ctf's aren't for the cxmb ur using.. wat i did was i got packed themes.. i downloaded it and when i opened the folder.. it was complete.. cxmb, plugin, and themes... use that cxmb and put the themes and those themes from that folder will all work :D hope i helpwd :D
I need help
To use the .CTF Themes you need to download the plugin called cxmb.prx
1. Download the plugin (cxmb.prx)
2. Extract the file and place into root of your MS0:/
3. Put the theme file (any name you like :)) under MS0:/PSP/THEME/
4. Enable cxmb.prx in Recovery (under VSH)
5. Go to Settings -> Theme Settings -> Theme to select your CTF themes
6. System will reboot to take effect
To Use the .PTF Themes download it first then put it inside ms:/PSP/THEME. if the folder is not there please create it. To apply the theme on your PSP, go to “Settings” => “Theme Settings” => “Theme”.
2answers
Ctf file wont work on my psp. but the site where i got my ctf file theme says that it works on psp 3.71 m33 version. my psp is 3.71 m33 version. why does it not work? what will i do?
you can try to check your ctf file using another psp,and see if it'll work.if it doesn't then the ctf file is the problem,you need to download and re-install it again,see how it goes.if still no dice,i suggest you try to look for other similar files to use on your psp.or you might want to upgrade your psp to 3.90 m33-2 at least to enjoy more options as far as themes is concerned especially the custom XMB themes (cxmb).if you have time you can check this channel: http://www.youtube.com/user/kr2008 .no guarantees,hope this helps.
3helpful
6answers
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
