Question about Kicker 06ZX750.1 Car Audio Amplifier
I did what you suggested..
I checked all the wiring behind the deck while the sub was working, and nothing i did made it start to cut out.i'm ruling out the amp as the problem because it doesn't just shut off; it will start to cut out for a few seconds and then it will switch into protection. the sub, which is a 4 ohm dvc is wired in parallel, which gives the amp and sub a 2 ohm load.i am lost at this point i thought it was all correct..checked all the positives and negatives to make sure they weren't crossed or anything, and it's a brand new wiring kit..
  • bushwhack364 Aug 16, 2008
    i have the same EXACT problem, it ran really good for a day and then it started cutting out, i thought it had something to do with the gain but i still cant figure it out
  • 109 Answers
Take it to a car audio shop that has test bench and ask them to check it for you.
Posted on Jun 19, 2008
Amp light is green getting a base like heart beat nothing else fuses are good
The only thing I'm wondering is if you shorted out the RCAs somehow. Try switching the RCA's to another output on the back of the deck, if you have more than one set.
If that's not it...you will have to add pieces of the system one by one, starting at the deck, to see if you can troubleshoot the problem. Very Odd.
Good Luck
Dec 07, 2013 | Autotek Car Audio & Video
Scotts S2046 Lawn Tractor electrical problem. Charged the battery, turned the switch and started right up. Put on the mower deck, turned the switch, nothing. Checked fuse, checked wiring connections but...
A couple of things -
*The battery could not be fully charged and starting depleted the battery reserve. Recharge and try again. Battery should read ~12.5volts fulled charged and not drop below about 10.5-11volts as you crank.
*Disconnect the deck and try it again. You may have cut/pinched a wire that grounded some part of the start system, There may be a connector to the deck that is not connected and your safeties are not letting it crank.
Dec 08, 2017 | Garden
I have all alpine speakers,deck,amp, and subs. My subs were working for about a year until one time i started my car and they keep cutting in and out .. at times they will work but then they cut off...
Sounds like blown subs, in the process of completely dying out, or a loose wire, possibly inside the box or from the box to the amp. Have your subs tested at a sound shop, or using a multi-meter, check for resistance across the sub terminals. An open line indicates a blown sub.
Jan 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
I just got the Kenwood Sub KSC WA100 from my cousin with no electric wires or nothing so pretty much what all do i need and where can i find it i will be putting it in a 07 nissan sentra 2.0
Subs are subs, they come with no wiring. You need an amp and all necessary wiring to get it bumping. What type of deck do you have? Where will the sub be placed? In the trunk? Amp install is easy. Also suggest purchasing one of those amp kits for $20-$30, makes it a bit easier.
May 03, 2009 | Kenwood KSC-WA100 Car Subwoofer
1000w amp not sending signal to subs
there is a wire that you must connect behind the radio deck that is blue, this is the remote wire, this goes from the wire to the amp and is what sends the signal that tells the subs to beat/make noise
you will want to run the wire from the amplifier to behind the radios wiring harness. this should fix the problem.
you also mite want to chek the settings on your deck and the volume settings on the amplifire
Apr 12, 2009 | Car Audio & Video
Amp or Stereo Cutting out...
I agree with what you think it might be. I really think its the deck that is bad and you should be able to take it back for a new one. Have you tried unplugging the RCA cables to the amp to see if that stops it? That would tell you if the amp is backfeeding or doing something weird.
Mar 02, 2009 | Dual Car Audio & Video
Sub not working after installing the jensen vm9022 deck
reinstall the factory radio use a digital volt meter to see witch wire supplies voltage when radio is turned on and off, note placement on harness then verify this wire is hooked up on the output side aftermarket harness you may have to jump it to get the maps to turn on. tip you can carefully pull unused wire from harness example (dimmer wire orange white) and move it to the position needed to keep it a clean install .
Nov 19, 2008 | Car Audio & Video
Powered Subwoofer won't work
This problem has many causes... but try this one... often when a faulty subwoofer speaker is to blame this test will tell you. Connect another speaker(any speaker) temp to check if there is audio still to the sub. Keep the levels down to ensure you dont go on a trail of destruction.
The spider wires from terminals on the speaker to the cone may be intermittent. I have seen this a lot on all types and makes of subwoofer driver!! This a common failure and can often be detected by tapping the speaker cone when it does the cut out thing. If it starts up, and they often do..., then you probably have intermittent spider wiring to the cone. A GOOD “Hi Fi speaker repair dood” can help here and replace the spider wires for you and save the expense of replacing the driver.
This is just one solution to the problem you are having.... there are many more..... and you should try this FixYa and see what happens. If you cant tell WTF then hit me back up here again. I work WITH YOU, to get the problem out for you.
If it sorted what you suspected... then rate me !FixYa!!.... Thanx
Dec 27, 2007 | Kenwood KDC-X590 CD Player
Kicker 06ZX750.1 Car Audio Amplifier Logo
35 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
