Question about Saeco Incanto Classic Espresso Machine
Wony load the circuit on start up for a saeco Incanto classic coffee machine
  • 40 Answers
SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 20, 2008
mirran
  • 515 Answers
SOURCE: Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Posted on Jul 19, 2008
  • 1089 Answers
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light.
Posted on Jul 01, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Incanto classic no coffee coming out, no lights flashing...
Check brew unit the screen is clogged.
Posted on Sep 19, 2009
  • 1089 Answers
SOURCE: how do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Posted on Oct 26, 2009
Coffee is too strong. How to dose Saeco Incanto classic? i tried to adjust SBS and beans regulator but coffee is strong and big coffee fills only quarter of cup.
press and hold the big coffee button while coffee is making,when you thing that amount is enough ,take of yuor finger ,Thats it. Next time just press the big coffee button once .
Sep 29, 2013 | Saeco Incanto Classic Espresso Machine
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Saeco Incanto
Hi
Jul 01, 2009 | Saeco Incanto Classic Espresso Machine
Our saeco incanto turned off for no reason-won't come back on.
Push on the right upper side of the door and see if the light comes on?
May 18, 2009 | Saeco Incanto Classic Espresso Machine
Coffee too weak
What kind of saeco incanto do you have?
Jun 23, 2008 | Saeco Incanto Classic Espresso Machine
User manual
Here is the link for the incanto deluxe if that is any use to you; http://www.espressoworkz.co.nz/Incantodeluxesbs.htm bottom right of the page is the download link. This link gives the manual for the incanto sirius; http://www.alattehotte.com/ProductCart/pc/adobepdfs/Incanto%20Sirius%20Eng.pdf Hope this helps, sorry no luck with a manual for the classic :)
May 06, 2007 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
168 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
