Question about HP Photosmart 8250 InkJet Printer
It just quit!
My printer jsut quit. It states the two way communications are not working and the "USB device attached is not recognized". I have cleaned the drivers, reinstalled and started over. Ready to just buy a new one.
Any help???
  • 26 Answers
Uninstall the drivers, search the registry for the name of the driver, remove any keys that include the driver or printer in them. Then, install new drivers from the manufactureres website
Posted on May 07, 2008
Printer doesn't respond via USB only WiFi
As my helper partner states, I quite agree but I would also use a different USB which the one you're using might be damaged, use another USB station cause maybe its also damaged. But if it states that the printer is offline...it will never print because its not selected as your active Printer. Actually you are sending the printing jobs to that printer wich is not active or recognized.
Apr 06, 2014 | Office Equipment & Supplies
Ridata usb drive gb not recognized
All apparatus attached to a computer are equipped with device driver applications whereby the computer hold the communication codes and as such talk to the instrument attached. Either the Computer drivers are not installed or active, or the attached device has a defect.
Jan 24, 2014 | Computers & Internet
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
Solution
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
Computer says there is no communication with the printer
Couple of things to consider and try,,,have you tried another USB device in the computer, like a flash drive? If it can read the flash drive ok then the problem is not the USB port. Try using a different USB cable for the printer. Make sure your computer is up to date with the most current drivers. To me it sounds like a bad printer cable. Another thing to try is having the printer attached and when the error message comes up try wiggling the cable to see if communication is restored. If so then chances are that the printer cable is bad. Hope this helps.
Jul 22, 2010 | Dell Photo 964 All-In-One InkJet Printer
USB connection not being recognized on Imageclass MF4270 all of a
First make sure that the USB cable is OK and use another if you have one. Then make sure that the laptops have working USB ports from Device Manager. If they are OK then try powering up the Canon again without the USB cable connected to see if any errors are reported and then plug it in to your laptop to see if it is recognised. Check the status of the Canon Print Driver settings. If this all fails then you may have defective USB ports on the Canon and will need to get them repaired.
Oct 06, 2009 | Canon imageCLASS MF4270 All-In-One Laser...
Usb not recognized , malfunctioned.
you need to reinstall printer driver .
"USB NOT RECOGNIZED" error come when windows cant to find driver of a new device .
Apr 27, 2009 | Office Equipment & Supplies
USB ports not working
check the status of usb port on device manager, install the updated usb driver
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Hp 1020 usb problem
ok..
remove the s/w through Control panel, add/remove software/programs
go here, for new drivers, hot off the press.
install once again
try it out.
Apr 02, 2008 | HP LaserJet 1020 Printer
HP Photosmart 8250 InkJet Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
