Question about Dell E207WFP LCD Monitor
My on/off button doesn't work anymore. I want to open the monitor, but it won't open. I have no idea how to open the monitor, I already unscrewed it, but it still won't open. How to open it, so you can get to the inside?
  • 3 Answers
I suggest trying to clean power switch, like someone said, using a straw. You have to split the end to make it go down by the switch and rotate it around the switch, then blow it out with electronic dusting air.
It worked for mine.
Posted on Sep 18, 2010
The disc draw doesn`t open when i press the open button
standing up or laying down?
when standing they sometimes stick, lay it down and if it still won't open then press down on the casing just above the eject button.
if that doesn't work then the unit will have to be opened, the dvd drive taken apart and completely cleaned.
Nov 15, 2011 | Microsoft Xbox 360 Console
2007 Eos bought end of May w/ 109K miles. Cruise Control switch doesn't work. If in ON position when cranked AND I can get up to a cruise-worthy speed, it'll work. But, then, sometimes it'll...
The cruise control issue is a common problem. The switch that is behind the steering wheel tends to wear out and the whole stalk will have to be replaced. I had the same problem with mine. It would work intermittently and over time it stopped working all together. I replaced the stalk and it was fixed
Aug 15, 2011 | Computer, Chip, Cruise Control for...
My monitors power light blinks red
I assume you have already try this monitor with other PC, just to be sure before opening up the case.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2010 | X2Gen MG19MY 19" LCD Monitor
The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
May 27, 2009 | Samsung SyncMaster 720N Monitor
Thanks for replying... i still need more help
Hi, sorry for the delay as i was on a journey
for the cable testing, you need a multimeter for testing the continuity, a star screw driver for opening the monitor cabinet, and a soldering iron.
First open the cabinet of the monitor. See the cable end connected to the board. Loosen the circuit board by unscrewing.
Connect and check each wire of the cable by touching multimeter probs at both the ends.
hope this may give an idea for solving your problem
thank you
Jun 24, 2008 | IBM E74 17" CRT Monitor
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
My monitor will either stay on and wont' turn off (even if you click the green button)
your Mnotitor Panel Switches gone bad replace all the switches and your monitor will be ok.
Ashok
Jun 08, 2007 | HP Compaq FP5315 15" LCD Monitor
Dell E207WFP LCD Monitor Logo
203 people viewed this question
Alun Cox
