Question about Dell Inspiron 8500 Notebook
No display I see the display on safe mode, but not on normal mode. Right now I use external monitor to boot up. Any suggestion?? Should I replace video card or lcd?
  • wilddngy May 07, 2008
    I'll try to re-install all my driver, and may have to re-install my professional XP version.
    Thanks Oldnovii and ThunderDan for your fast responses.
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    This is a notebook right? If you can see the video on an external monitor it is not the video card. Since it only works in safe mode it sounds like it may be a driver problem. What operating system are you running?
  • 14 Answers
I believe you are referring to a desktop PC.
You can press F8 repeatedly while booting to get the Boot options screen. It should contain a VGA Mode - this will boot your regular desktop with a lower resolution. Once in windows adjust the screen resolution to one that your Monitor supports.
Right click the desktop anywhere. Choose properties. Go to the right most tab "settings". Slide the screen resolution option until its where you want it. Click Apply. Do Not Hit any keys on the keyboard. Wait until it finishes changing resolution than click Ok. Close the Window.
If your screen goes black during this waiting 30 seconds should automatically revert it to the previous settings.
Posted on May 07, 2008
  • Daniel McMullen May 07, 2008
    I see you've actually posted this in laptop - either way it should still work the same.
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
How to force external monitor on lap top monitor broken boots on external monitor than switches right to broken monitor tryed f f3 f5 does not work
The issue is the OS boots but is not SET for the external monitor
You can try and use the FN and the monitor key but as a perm thing you cannot do this, just cannot be done its boots on the port for the primary display and that is the way it was built. Now if the F# or F% does not work then the operating system is not set up for the external monitor with the display broken i do not see a solution for this one as a tech,
thanks for the question tho but i want to remain honest and say its not possiable.
please do rate my answer before you leave thanks.
Aug 24, 2010 | Acer Aspire 4520 Notebook PC
Monitor problem
If it is clear with no lines when it boots and you see the Bios settings and splash screen it maybe ok... it may just be your Display Settings in your Opperating System. Use F5 to go into "Safe Mode" to reset. You toggle F5 at boot and select Safe Mode.
See if you can use an External Monitor. You may need to use the Function F4 Key or one of those to toggle the Monitor. If it works on the monitor and not you display then it could be your display screen. Fixable for 250-350 dollars typically.
If you don't get to Safe Mode sucessfully and not display on the external monitor... could be video card... and that meens motherboard replacement. Part is 200 and labor about 150-200.
Jan 24, 2010 | Acer Computers & Internet
Pavillion dv9000 screen is gray, with external monitor connected,laptop will only start in safe mode using vista ultimate
Your display drivers could be corrupt.
Boot the machine into safe mode. Right click on Computer and select manage from the sub menu.
When the window pops up select Device Manager.
A device list will populate. When it has look down the list for Display Adapters. Click on the + icon next to Display Adapters to it expands. Right click on the display adapter and select uninstall.
Restart the computer and let it boot in normal mode.
If it boots in normal mode let it detect the Display and install the drivers for it.
I would be a good idea to update the display drivers via the HP support website.
Oct 02, 2009 | HP Pavilion dv9000z Notebook
Acer -Video Display Issue
Hi there.
This could be 1 of 2 problems, lets start with the first.
#1 Bad display drivers
Boot the laptop into safe ( i am assuming you know how to do this by your post ) on the computer icon, right click and select manage, a new window will pop up and then select device manager, the list will populate with hardware that installed on the PC, look down the list for display adapters and click on the + sign on the left hand side to open the tree, then right click on the display adapter and select uninstall. Now restart the laptop and let it boot up as normal, if the display drivers were bad it will boot with the screen resolution as large, once you log in it should auto detect the display and install the drivers (you may have give it permission) if this works then that was the problem.
#2 Faulty graphics card.
Take advantage of the manufacturers warranty and send it in for repair as there will be nothing you can do about this kind of hardware failure.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 19, 2009 | Acer Aspire One PC Notebook
Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Apr 28, 2009 | Acer V193w LCD Monitor
I was playing online games on my sony vaio. Suddenly I got blue lines on the screen and the laptop stopped responding. So I tried restarting the laptop but I get blue thin vertical lines before the laptop...
Blue thin lines before it boots will rule out an operating system or driver fault. So it would appear something in the machine has failed.
Do you have a VGA monitor you can connect to it and see whether it shows the fault? This will show that if the fault also shows on the external monitor, it is likely an electronic fault on the main board, whereas if it works on the external monitor but not on the built-in monitor, my guess would be the cable that goes from the main board up through the hinge of the screen into it, or a connector, or an actual fault with the LCD display.
Windows booting normally once the display drivers were disabled indicates to me that Windows is no longer detecting the faulty display and therefore boots normally - possibly pointing to failed electronics in some way. It could even be corrupt BIOS that controls the video or something along these lines, though that's unlikely.
Good luck, either way it sounds like it's off to a computer repair shop. Is it under warranty?
Apr 27, 2009 | Sony VAIO VGN-SZ460N/C Notebook
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
The monitor on my laptop has been broken for a while so i'm using an external monitor, now all of a sudden when the laptop gets to the loggin screen it switches to the native (broken) laptop monitor and...
open the device mgr. and disable the internal and set the external as default windows should set it as default automatically when disabling the internal
Dec 21, 2008 | Computers & Internet
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Open Questions:
Dell Inspiron 8500 Notebook Logo
180 people viewed this question
Alun Cox
