My..spacebar..is..not...functioning..m..having..intex..keyboard
    Sergeant:
  • 203 Answers
Hi, if this keyboard is wireless try pressing the sync buttons on both 1st the USB connection device then 2nd the Keyboard (if it has them). If no joy then reinstall the Drivers that came on the disk. No disk then goto the website of the makers of your Keyboard and download the Drivers from there and install them.
If niether of these options work or the keyboard is just a plug in 1 then it sounds like the space bar is damaged... Ouch buy a new 1....
Posted on Aug 28, 2010
My space bar is gone on Samsung tab 4
I'm not entirely sure what you mean by it being gone. I do understand that the button's look was changed, and now it states the current keyboard language being used ("English (US)" being a common one), and it has a spacebar icon attached below it. That is still the spacebar, it just looks different. If it is not functioning like a spacebar, I would recommend changing the input type. Here is a link to how to do that.
http://www.dummies.com/consumer-electronics/tablets/samsung-galaxy-tab/changing-input-on-your-samsung-galaxy-tab-4-nooks-keyboard/
Feb 23, 2017 | Samsung Computers & Internet
How do you turn on *** q550 backlit keyboard
If the letters & numbers on your keyboard looks like transparent plastic, then you have a back lit keyboard, but if the letters & numbers looks like they are painted on the key caps, then you don't have back lit keyboard.
let's assume that you have a back lit keyboard: Hold the Function [Fn] key and tap the Spacebar once. That will enable/disable the back light.
You can easily tell if it's a backlit keyboard because the spacebar will have a keyboard icon on the left hand side. If it has the icon, then your keyboard has back lights on it & it should work.
If it doesn't, then it's a hardware issue that a technician needs to fix.
Aug 29, 2014 | ASUS Computers & Internet
Logitech DInovo edge spacebar not working
try to remove dust in your keyboard by using paint brush or compressed air.
Nov 05, 2013 | Logitech diNovo Edge 9676850403 Keyboard
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Jan 19, 2011 | Gateway 2520915 Keyboard
I have a IBM WW 1500 all the keyboard works but the spacebar, is this the function or keyboard or possible homming sensor failure?
If everything wirks but the space bar you probably have a keyboard problem. If someone had the space bar off it may not be properly installed. You can pop the space bar off and look for debris under it.
DickyO
Dec 02, 2010 | IBM Office Equipment & Supplies
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Jul 05, 2009 | Toshiba Satellite M45-S331 Notebook
Which 3 buttons are directly left of the spacebar?
Most Compaqs have the following to the left of the space bar:
Ctrl - Fn - Win Symbol - Alt
However some have this layout:
Ctrl - Win Symbol - Alt - Fn
If you post the model # we could say for sure.
Thanks for using Fixya.
Jun 24, 2009 | Compaq Keyboard
Spacebar key wont click back on
get a new keyboard...those springs that need to go under the keys if you loose them they never function the same.
Feb 14, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
