After inserting IDE hard disk in intellistation the unable to get display and long beeps are repeating.
    Scholar:
  • 166 Answers
Re-attached the video cable. The beeps indicates a loose connection with the display adapter. If the same thing happens, it seems that you have a loosed video card, make sure its properly seated on the slot. Please let us know if the information has been helpful. Thank you and regards.
Posted on Aug 28, 2010
  • Ronan Reynera
    Ronan Reynera Aug 29, 2010
    Well beeping sound indicates a hardware error. Re-Seat the the memory modules that looks like a ruler and make sure that its properly fitted on the slot. (Before you do this, make sure that you have remove any power source to avoid accidents). Please let me know of the outcome. Thank you and regards
My machine does not allow the operating system to load. Red light and sequence of five short beeps repeated five times. (Fails to Boot)
May be your OS is crashed
First you should check your RAM that is inserted correctly and the IDE cable of hard disk stable correctly with motherboard.
if all hardware is ok then you should reinstall your OS by Bootable CD,
Jan 12, 2011 | Computers & Internet
I have IBM Intellistation Z Pro 6221. I tried to install XP, I press F6 for SCSI driver. Then It prompts Press 'Enter' for install or 'R' for repair. Whatever I press it displays No hard disc detected
You need a floppydisk including the Driver for the SCSI or Sata drive - Depending which HD You are using.
If the controller is in motherboard You will find the driver from motherboard webpages.
If it's a separate controller card - You will find it from it's web pages.
XP doesn't support too well sata if it's not the XP SP3 version media.
You may need to change the sata to compatibility IDE mode to get it up and running.
Jan 06, 2011 | IBM IntelliStation Z Pro 6221 PC Desktop
Unable to see monitor. saying no signal. Will not switch to monitor. When I turn computer on I hear a beep beep beep beep. Then nothing
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 03, 2011 | Computers & Internet
My computer display a message "insert a bootable disk no harddisk attached"
replace all connection leads that attach to your hard drive including electical from your PSU unit to your hard drive and IDE or SATA from your motherboard to your hard drive
hope this helps
Aug 09, 2010 | Computers & Internet
I'm unable to connect phone to PC. Phone beeps then displays unable to connect problems with search?
probably one of the driver is missing,you need to insert the disk which came with your phone and store lg suite on your pc
Jan 09, 2010 | LG KC910 Renoir Cell Phone
Does not see hard drive
configure the bios settings, hdd should be scsi. maybe your current settings is sata or ide. if not work check the scsi controller if have installed driver or compatible to your unit.
Oct 10, 2009 | IBM IntelliStation Z Pro 6223-31U PC...
How to install Adaptec SCSI driver when installing XP -Z Pro 6223
you have to use sata xp cd to intall that driver no need floppy disk.
Aug 19, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Intellistation e pro acts as if booting, but doesn't
Its nothing but the port of your display cable in computer tower and the display card. If its inbuilt (on board) display card then the slot where the extention is linked. If you can then just open the tower and change the slot of the display card. 100% gurantee it would work.
Jul 28, 2009 | IBM IntelliStation E Pro 2D PC Desktop
Intel motherboard crash
you definitley not find display without the ram. that's why it beeps without it, sign of problem no RAM. It should be your video display. can you cck is you have built-in display? if not, then check the display card if properly insert. if its ok inserted, then replace your video card or find a substitute to confirm defect.
one advise, if you keep on testing our board on and off? remove first the power cable of your hard disk drive to prevent damage to the disk continues on and off. when you get the POST display then that's the time you put back the hardisk power.
good luck..
redrivera
Mar 15, 2008 | Intel Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
