Help me my pc has a problem and i think it's from the motherboard. I can't start my computer and it doesn't work at all. But sometimes it worked well. Nothing happen. But when i shut down my computer and when i start it again, it doesn't start. My hard drive, RAM are all find. It's the motherboard it does not start. can u help me??
    President:
  • 2,351 Answers
You can try resetting the cmos/bios by unplugging the power cord. Open the case. Find the battery mounted on the board. Use a flat tip screw driver & lift out the battery. (About the size of a quarter). Wait about 15 seconds & pop the battery back onto the board. Plug you're power cord back in & power on the PC. If the system still does not boot, re-check all data & power connections for solid connection. Remove you're memory & firmely reseat. Try again. Still no? Replace power supply.
If the system still does not start & or gives no beeps, no LED lights & no fans power up. Than you're board is most likely dead. (So hate giving out bad news)
Mike.....................
Posted on May 08, 2008
I have a K8V-MX motherboard. Recently, when i start the computer i will sometimes get no video, sometimes i will. When it doesn't work the monitor just goes into power save mode. Everytime everything...
that happend to me aswell, coz the asus motherboard are like that.
1st unplug all the cabels from the mother board like, harddrive ID and Cd-room ID, leave just the power supply on and try to start Your computer if it doesnt work take off the cabels of USB or anything else that is connected in the motherboard and try to switch it on, if that doesnt work.
get another graphic card and try with it maybe u have prob with ur graphic card, and if that doesnt work take of the motherboard from ur case and try to switch it on like that coz ASUS MOTHERBOARD are really silly sometimes.
hope that Helps.
Sep 20, 2011 | ASUS K8V-MX Motherboard
My EasyCap DC60 shows the greean light when I put it in the computer but it doesn't show the video and because it doesn't show the video I think the audio doesn't work. Please help.
You need to reset the BIOS of the Motherboard.
For easy repair, just remove the battery ( looks like a button ) on the motherboard,wait for 1- 2 minutes, then place it back again, that way should fix the problems
Aug 22, 2011 | Computers & Internet
I can see the POWER LED light when I plugin laptop on power as well battery. But when I press the power button to start laptop, it doesn't boot. I can not see and LED lightning up when laptop is on...
Try finding an external monitor and hooking it up via the VGA port on the side of the computer. Once it's hooked up, hold down the function (Fn) key and find and press the key for external monitors (usually it's F4 or F6). It will probably look like two little squares with an arrow between them. Press that button a few times (waiting about 5 seconds between presses, and continuing to hold the Fn key) to see if anything shows up on the monitor. If so, then it's probably something to do with your backlight.
Sometimes what happens is your LCD backlight/backlight inverter stop working. These can be purchased and replaced, but it's not a very easy procedure. If you see something on the monitor let me know and I can try to help you with the disassembly process/ordering process.
If this doesn't solve the problem, then I would suggest that there was an issue with your motherboard, in which case you would usually hear some beeps on start-up. The beep codes will help you diagnose what's wrong. If you comment back with the beep codes (if this is the case, that is), I can look them up for you and see what you've got going on.
Hope I helped!
Tj
Jul 20, 2011 | HP Pavilion Dv6910us Notebook
Have a Pavilion Desktop HP with upgrade from vista to windows 7 ultimate. Turned the power on and no blue light and no monitor yet the fans were running. Computer monitor said no input and went back to...
First I think you should do some troubleshooting. Try hooking up your computer to a different monitor and see if there's any display when you boot up. If that doesn't work, then open up the desktop and make sure all of the power connections are solid. One that sometimes comes off is the 2nd motherboard power connector. Because you aren't seeing the blue LED, I think it might be that connector. The motherboard has one 24 or 26 pin power connector and one simple 4 pin connector. The 4 pin is usually in a corner near the processor. Take a look at that to see if your motherboard is getting all of the power it needs. If everything is connected properly and your monitor isn't the problem, the new power supply you ordered could fix the problem. I hope this helps!
Apr 15, 2011 | HP Pavilion a6750f PC PC Desktop
Hi, Computer is not able to start because its not able to perform POST. CMOS/BIOS is not starting.Nothing displayed on monitor when starting computer. I had reinstalled XP then when i had reset BIOS...
bad leads
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive they probably be faulty
hope this helps good luck
Sep 07, 2010 | Intel D850MV Motherboard
Acer laptop problem: Hard disk/motherboard problem
Try 2 things....1) replace the IDE controller cord or the SATA cord whichever applies. If this doesn't fix the prob try downloading latest mobo updates as well as any Acer updates for your specific model. Let me know if any of this works.
Thx
Jul 31, 2009 | Computers & Internet
Computer wont turn on or boot
what size power supply are you using, if its under 400 watts it may just be under powered. Large video cards 512mb and over take a lot of power. Try removing the video card and see if you can get the pc to power up, hopefully you have on board video.
How did you blow the cpu_fan connector, did you short it out? I would first supect the power supply is under rated, second a blown power supply, or mother board.
Mar 14, 2009 | Computers & Internet
Miffed!!!
There could be a couple of possibilities. But the most likely one I can think of is a fault in the atx connector(The broad 20 pin connector) either on the power supply or the Motherboard
At most Electronics or computer specialty stores you should be able to get a Power supple tester for about $20 USD.
You can connect that to you Power Supply Unit(PSU) and that should be able to tell you whether your fault is in the PSU or the Motherboard
Hope this helps
Dave
Nov 07, 2008 | Computers & Internet
Doesn,t display on moniter
try reseating the memory chips or video card
take the card out, anything that loose.
if beeping occurs means something is loose.
the memory might be bad too.
Jun 18, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Not running on startup
I occasionally have a similar problem with a couple of my KVM?s and I think it relates to the circuitry in the KVM that is supposed to fool the PC into thinking a mouse/keyboard is attached. Windows doesn?t see the mouse so it doesn?t load the drivers unless you force it. What works for me is to just start the PC and switch the KVM to that PCs port and leave it there till the computer finishes booting. Then its safe to switch to the other port, probably not the elegant solution you were looking for but it works every time.
Jun 18, 2007 | Belkin OmniView SOHO 2-port KVM Switch
Computers & Internet Logo
474 people viewed this question
David Payne
David Payne
