Question about Nikon Coolpix S210 Digital Camera
Memory card is write protected- the only thing appearing, denying access to recording or clicking photos.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 29, 2010
How do I access protected images?
digital heaven perhaps did you unlock the sd card before trying to upload .small switch on the side of card .
Aug 27, 2015 | Nikon Coolpix 5200 Digital Camera
Import pictures Nikon D3100 get access denied
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Jul 17, 2013 | Nikon D3100 Digital Camera
Msdc read sector donot read memory card solution
Hi
For cards like san disk you have to unlock and remove the password in the drive that is denying user access. And then you have to use a recovery tool to recover back photos from sandisk SD card. A Tool that worked for me more effectively is..
http://www.advancedphotorecovery.com/recover-photos-from-sandisk-microsdhc-card.html
Mar 16, 2013 | SanDisk 2GB microSD Memory Card
My computer can't access the pictures on my Panasonic Lumix DMC LZ3 anymore. It begins to download the pictures and then a message saying access denied comes up and the download is halted. I have tried...
Easiest answer is to take the memory card out of the camera and insert it into a card reader on the computer. This will bypass any problem caused by the camera settings.
Possible reason for "access denied"- you may have protected the pictures in the camera to prevent accidental deletion. This would give "access denied" if you were moving the pictures to the computer rather than copying them, because the move function deletes the originals on the camera after making a copy on the computer. Use the right mouse button to drag the pictures and you will get a dialog allowing you to choose "move" or "copy". I similar problem can happen if the memory card has its write protect switch on.
Oct 26, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
Problm with meu 850SW
You may try some recovery software to rescue the files on your sd card, here are some for your options.
Photo Video Recovery (for Windows)
Photo Video Recovery for Mac
Be careful: Before your files are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jun 08, 2010 | Olympus ? 850 SW Digital Camera
Pictures were taken with my SONY CYBERSHOT 10.1 camera - but there was no memory stick in the camera. Now the picture are in the internal memory. I've tried to delete them, but I get messages that say they...
first of all remove any memory card you may have in the camera.. Then connect the camera to your computer using the USB cable provided. Then Switch on the camera, Once windows has recognised your camera, open up My Computer. There will be a removable disk icon appeared, open it up. Open the DCIM folder, then open the 101_SONY folder. This now has given you access the area where the camera stores you photos. select the first file by left clicking on it, then hold shift and left click on the last file, they should all now be highlighted. Now right click on the last file. and select properties from the menu. On the window that appears, deselect read-only checkbox and click Apply. Your photos will now no longer be write protected and can be deleted.
Hope this helps
Jun 05, 2010 | Sony Cybershot DSC-T77 Digital Camera
I have a Fiji Finepix Z20fd camera, and have approx 350 photos on the memory. Yesterday the message "memory full" appeared when i tried to take a photo so naturally i attempted to delete a some to make...
Having pics on both the internal memory and a memory card is asking for trouble. Take out the card and download the internal memory to your computer. Then, go into the menu and find "format" and erase the internal memory. Then, download all the pics from the memory card using a separate card reader. Then, insert the card into the camera and do the format thing again to erase and optimize the card. Now you have a fresh start...never use the internal memory again.
May 03, 2010 | Fuji Finepix Z20fd Digital Camera
Cannot remove photos from phone. trying to copy
try hard reset
instructions here:
http://search.vzw.com/?do=viewdoc&id=15345
Mar 28, 2010 | Samsung i760 Black Phone
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Apr 18, 2008 | VuPoint DV-DV1-VP Camcorder
Denied access to MMC to motorola cell via usb
Try to reformat the memory card with a Laptop or PC then try put it in. Or use the formatting tools on that phone to format the memory.
Aug 04, 2007 | Motorola Mobility E398 Cellular Phone
Nikon Coolpix S210 Digital Camera Logo
81 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
