Question about Philips Electronics - Others
How i check capacitors with multi meter - Philips Electronics - Others
    President:
  • 1,139 Answers
Ideally you want to check a capacitor with a proper capacitance meter although it can be possible to check them with a multimeter.
If the size of the capacitor is very small, say mircofarads you probably wont be able to test it, however we will give it a try.
Discharge the capacitor first by shorting out the pins. BE WARNED!! IF IT IS A LARGE CAPACITOR OR A CAMERA CAPACITOR DO NOT ATTEMP THIS!! Capacitors can be very dangerous if handled incorrectly.
Find the polarity of the capacitor, there should be a black stripe that runs up the side of the capacitor with a negative sign in it, the leg that is closest to that is the negative.
Set your multimeter to resistance, 10k-1M ohm. Put the probes on the legs of the capacitor and instantly watch the display. The multimeter should show close to 0 ohms and then start increasing slowly. This is because the battery in the multimeter is actually charging the capacitor through the test probes.
If the capacitor shows this pattern then you are pretty much assured that it is working properly.
I must say again though, please be careful around capacitors as they can be very dangerous.
Hope this helps and thank you for using FixYa
Posted on Aug 29, 2010
L3000Dt only starts when you go direct to solenoid to start or bypass fusible link. no 12V at starter
Check the power supply capacitors. Take a good look at them and if they are rounded on top they are probably bad.
If you think they are bad, measure the capacitors with a multi meter. They are suppose to have the value written on the side of the capacitor. Remove only one leg of the capacitors with a soldering iron and take the measurement. Be sure everything is disconnected and the capacitors are shorted out by taking a screw driver and touching the two capacitor leads together. Especially any large capacitors. Be Careful !! I am not responsible if you decide to do this yourself.
There are multi meters that have a setting just for this purpose. And replace the fusible link it is obviously burned if it works when you bypass it.
Oct 22, 2017 | Cars & Trucks
Fan comes on but don't think the compressor is coming on. What can i check?
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
May 20, 2015 | Refrigerators
I just bought a KIC fridge n it doesn't turn on the light n it's not cold inside
CHECK FORpower at the outlet,checkfor 120 volts.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Apr 23, 2015 | Refrigerators
Stop working
Fridge not starting?
Mar 14, 2015 | Refrigerators
Why refridge does not work
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
Aug 31, 2014 | Kenmore Refrigerators
How do i test the large capacitor on my A/C compressor
You need a multi meter with a capacitor test mode on it to check it accurately. The large silver capacitors usually have a swollen end when they are shorted but not always.
May 09, 2014 | Carrier 38BRC060 Air Conditioner
Danby portable washer &dryer won't start.None of the motors will start & I was wondering if the capacitors could be shot ? I have checked for kinked hoses, loose connections without luck.this is my...
Hello Robriw,
If the units have capcitors this would stop the units from working. They are usually inexpensive compared to other parts you have to purchase for the units. If you have a multi meter that you can check the capacitors resistance this is how you check them.
1. Remove the capacitor and discharge by place shorting between terminals
2. Set your multi meter to resistance
3. Take one lead to each terminal
4. The meter should jump up quickly and then slowly go back to infinity
5. Swap leads and do the same
6. If it does this both ways the the capacitor is good, if not they need to be replaced.
Thank you for choosing FixYa.com
Justin
Apr 24, 2011 | Washing Machines
I have the same problem described above. I followed the information above in the best solution and did a visual inspection of the capacitors. I did not observe any bulging or raised tops. Is there a multi...
Capacitors are only one problems,viewing capacitors inspections are best and easiest ways.U want to test it with a multi Voltmeter look for capacitors Microferet and voltges each one,just test it.U have no skills or trouble shooting experience in electronics devices.Well no amount testing of capacitors,will not solved the tv problems,could be any things in the power supply board is slicely variable voltages could cause power problems.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 29, 2010 | Samsung HP-T4254 42 in. Plasma Television
Stoped working
The most common reason for this is that you have a bad capacitor. If the capacitor is bad, and not sending enough "juice" to the compressor, then it will "click" off on overload. Capacitors can be checked using a multi-meter, set to check mFd (microfarads)
Jul 24, 2010 | Whirlpool ACC108PS Air Conditioner
Electronics - Others Logo
803 people viewed this question
Top Philips Electronics - Others Experts
Bill Boyd
Tom Chichester
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
