Question about Canon EOS Rebel K2 35mm SLR Camera
Action shots i recently bought this camera and havent taken any shots yet but i figured many people on here would know how it is with action shots, such as snowboarding and skateboarding.  and what settings would be better to use for those kinds of things thanks very much
  • 2,016 Answers
Action shots generally require a fast shutter speed -- to freeze the motion. So you need plenty of light or a "fast" lens. A fast lens is one in which the aperture opens further to let in more of light. The smaller the number of the maximum aperture, the faster the lens, so a 28-105mm f/3.5-4.5 lens is "faster" than a 28-105mm f/4.0-5.6 lens. But usually, faster lenses cost more.
For the settings on the camera, the Rebel K2 has a Sports image mode (silhouette of a runner) on the control dial which should get you appropriate settings for most action shots.
If you want to set the shutter speed yourself use the Tv mode, and with a fixed shutter speed, the camera will set the correct aperture. Watch in the viewfinder -- if the aperture value is flashing, it means the shot will be underexposed. You will have to select a slower shutter speed.
Another way to get action shots with limited light or a "slower" lens is to use film with higher ISO/ASA. ISO 100 film is good for daylight shots, but for inside shots or evening shots, use ISO 400 film. Higher ISO film is "grainier", so enlargements will show less detail.
Posted on May 07, 2008
Hi, my sony dsc - t300 doesnt work well on pictures taken at night. the images appear blurred. problem started on recently in june 2010 during the world cup. how ever if you take pictures on well light...
Change the ISO setting to a higher figure but not too high or you will get color distortion or use a tripod or rest camera on solid object and use the self timer
Aug 12, 2010 | Sony Cyber-shot DSC-T300 Digital Camera
I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Jul 26, 2009 | Nikon D60 Digital Camera
Blurred pictures on action shots
For daytime, make sure the ISO is kept low, say 100, or 200 if a little dull. For nighttime or indoor, you may need to increase the ISO up to the max of 1600.
Check also the AV+/- setting isn't set too high - are the shots brighter than normal? If so, hold the AV+/- button and use the scroll wheel to bring the setting back down.
One other thing to check is your CF card - have you changed cards recently? I have two 2Gb UltraII cards from Sandisk - one is really fast, about 1-2 pictures per second, the other is really slow, about 3-4 seconds per picture. They should be the same but are not.
Also try shooting in AV mode to keep the lens wide open and get the fastest shot possible.
Hope this helps!
Mar 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I bought a canon powershot sx10is about 3 weeks ago when I bought it I told the salesman I needed it for sports action all I get is blurry pitures
This is a common problem with digital cameras. Canon makes a great camera you just need to know the trick. The shutter release has two stages the first lets the camera do metering the second takes the pic. to get action shots you need to frame the photo before the action ( set up the pic in the veiw finder or lcd display) the press the release to the first stop and wait for the green box or bracket (depending on model) the shot is now ready as soon as you press down the rest of the way it will immediatly take the pic.
this is the only way I'm aware of to get an action pic with a digital point and shoot. You bought a great camera but it's not quite an SLR.
hope this helps
Dec 11, 2008 | Cameras
Action Shots are going to slow
not entirely sure what you mean, but it sounds like you may need to increase your ASA setting to capture the action. If your camera allows it - push your ASA setting to 400..
I hope this helps
Apr 24, 2008 | Cameras
Action shot blur
you seem like you have the problem with the focus button
with action shots,to get a good shot
you must hold down half of the capture button ( the button u press to take a foto)
if successful, you will see a little green dot on the top of the screen.
Your camera is now on focus.
all u have to do is press the button down a little harder and your shot wil be taken straight away.
good luck.
angie
Apr 08, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Canon Powershot A75
I move the control dial on top of the camera from AUTO to the running figure for action shots, but there is still some delay - you need to snap the photo just *before* the shot is perfect
Dec 13, 2007 | Canon PowerShot A75 Digital Camera
SONY CAMERA DSC-P52
have you tried formating the memory stick on the computer and see if that works? how did you put the pictures on the computer? via the USB that came with the camera? or did you use the memory stick and put it into the camera?
Nov 11, 2007 | Sony Cyber-Shot DSC-P52 Digital Camera
Miss all the action shots with this camera
The longest part of the shutter delay is caused by the autofocus mechanism. Most cameras will let you press the button half-way down and wait until the autofocus is locked. Then wait for the action to occur. When you press the button the remaining distance, there will be a shutter delay of about 0.2 seconds before the picture is taken. Using that technique will let you capture action shots. There is no way to improve shutter delay on any particular camera. The newer digital cameras are showing improvement in this area. Some are achieving autofocus lock in 0.4 seconds and shutter delay of an additional 0.1 seconds.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Canon EOS Rebel K2 35mm SLR Camera Logo
88 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
