Question about AKG C418 Professional Microphone
AKG C418 is not working!
How do I determine whether or not the 418's diaphragm is working? I've already determined continuity in the internal wiring.
  • 2 more comments
  • tshogy May 07, 2008
    Hello Shaggyrat,
    Thanks for your response. I'm not sure you understand what I'm asking. I'm not speaking of a software or driver problem. The problem I'm having is with the microphone. Though I'm using 48v it is totally dead. I took the mic apart and checked continuity with a meter. Please let me know if you know how to actually test the capsule.
    Thanks
    Hello Shagyrat,
    Thanks for the engineering tips but I have engineered for over 30 years. My question is pertaining to testing the capsule in order to find out if it's fried or if there is just some internal loose connection.
    Hello Shaggyrat,
    Sorry but testing a condenser through a guitar amp is totally besides the point. I need to talk to a tech about how to test the capsule of the mic.
  • tshogy May 22, 2008
    That makes total sense! I do have another c418 so,  I can try that.
    Thanks!
    Tony
Most people do no use just one C418. If you have another C418 or other model from the MicroMic series, borrow the PCB located inside the XLR housing. Replace the board on the defective C418. If the mic now works, the original PCB is defective. If it doesn't, it is safe to assume that the capsule is fried.
Replacement parts are available from AKG at 818 920-3279. When soldering a capsule, use the hottest solder iron possible. Iron contact with the solder terminals longer than two seconds can burh up the capsule. The faster you can flow the solder and remove the iron, the less likely you will damage the new capsule. Be sure to use a heat sink to dissipate the heat as fast as possible.
Posted on May 22, 2008
    Genius:
  • 1,224 Answers
It works its probably just that you dont have your drivers set up right same problem here with my usb mic you gotta go into sound and change the standard mic to the mic you want to use and if you have a web cam mic also hooked up you will want to disable web cam mic (not the web cam) in drivers these 2 mics are having conflict of interest
Posted on May 07, 2008
  • Christophe Thompson
    Christophe Thompson May 07, 2008
    this mic is a condensed mic which requires 9-52VDC phantom power
    The mic can handle SPL’s of up to 140dB with 3% THD or 131 dB with 1% THD. The signal to noise ratio is 56 dB (A-weighted)
    There are two versions of this mic: C-418PP and C-418L. The PP version has the standard XLR connector and requires a mixer or source that has phantom power. This is the most common version. The ‘L’ version has a ‘Mini’ XLR connector that is used with the AKG B29L battery operated power supply, MPA-V-L external phantom power adapter, or the WMS body pack transmitter.
    The C-418 has a hyper-cardioid polar pattern which means it has a narrow pickup field and rejects sounds from behind and to the sides. This is one of the main reasons the mic is great for drums. One thing you may want to test for and that is placing the mic so it picks up the sound of the cymbals bouncing off of the top of the drum head. You can angle the drum just enough to redirect the reflected cymbal sound away from the mic element. If you want a tight and punchier sound then aim the mic towards the perimeter of the drum head. For a more rounder and natural sound then aim the microphone towards the center of the drum.
    Some microphones have switches where you can reduce the decible input, or "pad" the input. Well the c418 does not, so you need a mic preamp that has a button to do the reduction
    do you have a regular guitar amp try the old fashioned hook it up turn it up for the mic sorry just caught on to what your saying but it states that to test a mic you gotta put under an amp my grammer not the best but i try my brain fried from too much thinking lol i have a behringer amp that has built in mic testers on them in the back for even the worst of mics to make sound good
How do I test the heating element?
Looking at the element does not determine whether it is OK electrically. A continuity test with a multimeter will determine that.
Jan 03, 2015 | Dryers
On my 2001 Nissan Quest 3.3L #5 cilynder miss fire replace sparkplugs, wire, distributor, and injector still miss fire so I hook a noid light to it, it won't light up at all can it be the ECM and if you...
I don't know where it is, probably under the passenger side dash. But before condemning the ECM, check the wiring to that injector. First try to determine if it is the power wire or the ground wire for the injector which is lost. With key on, the yellow power wire should have voltage on it at the injector connector. This is independent of the ECM-only the ground wire goes into the ECM, to be internally grounded to pulse the injector. The #5 ground wire is a yellow-green wire.
If you have voltage on the power wire to #5, key on, then we know either the ground wire is bad (broken or open) to the ecm -or the internal ground for that injector is out, inside the ECM.
To determine whether it is the ground wire or the ECM, you will have to locate the ECM, pull the electrical connector off to it (Be sure and take the negative battery post off, first.), then locate the yellow green wire at pin #106 of the ECM electrical connector. Now test the continuity of that wire from the injector connector to the ECM connector-use a voltmeter set to ohms. If the wire has continuity, then the ECM must have a problem- the internal injector driver for #5 may have failed. Also look for a bent pin at #106, or anything amiss in the electrical connector. In most cases, it is not the ECM but a wiring problem.
Good luck. To locate the ECM, register for free at autozone.com, listing make, model, and year. Look under "repair guides", then component locations-it should tell you the location of the ECM.
Oct 04, 2014 | 2001 Nissan Quest
Sony sxrd has no sound
a short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switched on or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here that you have not already done--make sure if Sony the remote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Mar 29, 2012 | Televison & Video
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
I am getting a senor error display on the screen I already flipped the breaker and tryed to reset still havin the problem it is not heating
Hi.If the breaker trips off it means here is something wrong with the internal circuit.You can tests the continuity of the circuit using a MULTITESTER.This will helps you to determine whether short circuit did not occur in the circuit.Use both ends of the wire connecting your oven with the positive and negative ends of the tester.If testers pointer moves to the right hitting the maximum point .It means short circuit happened..
Jun 22, 2011 | Microwave Ovens
My D112 died midsession. Can it be reconditioned? Is it cheaper to fix or replace?
Being a dynamic microphone there is not much that can go wrong with it apart from:
  1. broken / detached wiring
  2. failed diaphragm capsule
before doing anything else check it isn't a cable fault.
AKG products normally have a 2 year warranty so if it's inside that time take t back for repair / replacement.
Otherwise a competent repairer ought to be able to fix it for you cheaper than replacement
Feb 22, 2011 | AKG D112 Professional Microphone
AKG D12E, WIRES INSIDE SEEM OK AM GETTING GROUND HUM BUT NO SOUND OTHER THAN GROUND HUM
One of the coil wires in the diaphragm might be broken. Try testing it with a volt ohm meter.
Jan 22, 2010 | AKG Audio Players & Recorders
I dropped my mike (not a a big fall) and now it doesn't work.Help
Mikes are very fragile things and if you consider that the wire on the diaphragm is hair thin then you will understand that when dropped it will break easily. Also the magnetic field of the magnet is distorted by the impact. If you can get the wiring connector apart where the mike cable plugs in try testing for continuity on the 2 wires coming from the cartridge. Use a high resistance reading and work downwards. If you get nothing you will have to decide whether you want to replace the cartridge or buy a new mike. Sorry for your bad luck. I have 2 AKG mikes circa 1966 that it happened to that I still keep as a reminder.
May 20, 2009 | Samson R21 Professional Microphone
Plastic housing on c419 broken
Sorry that the parts list is in German, but at least you can look at the visual, see how they are put together and order the parts. Although this microphone has been discontinued, parts should still be available from AKG.
See the pdf file at the following link:
www.akg.com/mediendatenbank2/psfile/datei/47/C4184055d1f88cd3f.pdf
You will also find the email address and phone number of the American distributor. You can also visit akg's website at:
http://www.akg.com/
If my assistance helps you solve your problem, I'd appreciate your rating. Thanks for using Fixya.com
Jan 27, 2009 | AKG C418 Professional Microphone
Mic repair
Oh sorry, it was an AKG c418. However, shortly after i posted, i stared at the thing long enough and managed to get it apart, fix it and put it back together. thanks
Feb 28, 2008 | Audio Players & Recorders
AKG C418 Professional Microphone Logo
776 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
