Question about Planar PL2010M 20" Flat Panel LCD Monitor
Monitor flashes and then turns off and won't turn back on
The monitor worked fine for months, then all the sudden i turned off my computer, then rebooted it and it just flashes on and then goes black but the light is still green? i have no idea what is going on.
  • 5 more comments
  • Anonymous Jul 08, 2008
    Exact same problem. I've swapped it to a 17in Planar on that same computer and its fine so its the 2010M that has the issue. Funny thing is it displays the image for maybe 1/8th of a second then goes black but you can clearly see the video from the computer during that time
  • Anonymous Jul 29, 2008
    Same thing, what is wrong with this thing! I hate it so much right now. Why cant planar fix this thing!
  • Anonymous Aug 14, 2008
    Exact same problem: the monitor worked fine for months, then all the sudden i turned off my computer, then rebooted it and it just flashes on and then goes black but the light is still green.
  • Cammy Snyder Latimer
    Cammy Snyder Latimer Sep 16, 2008
    same thing. When it flashes off, I can press the power button off then right back on, the screen comes on then blinks off. I can go into programs REALLY fast if I am ready to look and get my currser to it before it goes black again and when I turn it back on, the program I pulled up is still on the screen.
  • Anonymous Oct 05, 2008
    Same issue on my Planar 2010m blinks video for a second and you can see everything as it should be and then goes dark, the green light doesnt turn to yellow standby.
  • kennren Oct 10, 2008
    I have the same issue and the monitor is only 1 month old
  • DuoDreamer May 11, 2010
    thesimulacre: I have been trying to open this same monitor to check for blown caps that I can replace, as I'm having the same problem. How did you get yours open? I have removed all of the screws, but it is still stuck solidly together. I don't want to break it.
I have 3 of PL2010 and they have the same problem. Everyone of them flashs and it goes black.
Posted on Aug 01, 2008
  • 4 Answers
Usually bad caps on the power board. I can guide you through it if you have some soldering experience or I can fix it for shipping + tip to colorado.
Posted on Jan 10, 2009
Computer monitor HP Pavillion keeps clicking and flashing but won't turn on the screen
you need to bring your PC to a technician... Its the best solution for that. It will save you time and money.
Mar 08, 2013 | Computers & Internet
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
The monitor either won't turn on or it flashes off
Your monitor has been dying over the last two or three months. Unless you have a local repair shop that will work on monitors, it's time to replace it.
Mar 06, 2010 | Computers & Internet
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Same problem
It may be the back plane lamps, and or the back plane power supply that is in a failing condition. If in your model they are changeable, they should be changed together.
You can verify this by turning on the monitor, feeding it with a known working source, and shine a flashlight in to the screen at an offset angle to your view. If you can see some image in the screen, then you know that the monitor itself is functioning, and the problem is back plane lumination.
Jerry G.
May 07, 2008 | ViewSonic VX900 19" LCD Monitor
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
MONITOR PROBLEM
This may not be a Monitor problem. So if you can try to get to test monitor on another computer. Check carefully the data cable to ensure there are no bent pins. If it turnout to be a monitor problem then at only 6 months -Acer should replace it. If the monitor works - you should have the graphics card on the computer checked out. If you feel you can do this - and you can- basic checks come back as another request.
Jun 06, 2007 | Acer AL1916B 19" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Monitor won't work
Try adjusting the video connection on the back of the monitor and kinda wiggle it from side to side to see if there's a loose connection. One other thing to check (In case it's a newer LCD) is that the video isn't switched to DVI (It should be automatic, but it can't hurt to take note of this)
Mar 27, 2007 | Jetway M1901DS (Silver) 19" LCD Monitor
Planar PL2010M 20" Flat Panel LCD Monitor Logo
1,586 people viewed this question
Top Planar Computers & Internet Experts
Clive Gray
Joe Goldman
Joe Goldman
William Miller
William Miller
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
