Question about HP Pavilion dv7-1129wm Notebook
When i boot my computer the screen stays blank and two lights flash on the under side of the keyboard what does this mean
    Scholar:
  • 156 Answers
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Posted on Aug 29, 2010
My acer laptop does not display but it runs.what is the problem?
Shari,
There are many things we can try to find out why this is. To start, When the computer boots, Do you hear the windows chime? this will indicate the laptop boots. otherwise we could be looking at other hardware.
With the laptop turned on, if you hold a flashlight to the LCD you may be able to see faint images. This would indicate an issue with the LCD or the Inverter located in the laptop and you should have it serviced by a professional to repair such items.
Also while booting the laptop we want to watch all the lights on the laptop. Occasionally when a hardware item fails we identify it with a bios Beep code. In laptops this is a flashing light that will blink either by the AC plug, Right under the LCD, or the front of the laptop.
When we start the laptop does the fan spin up very hard and then slow down again? do we hear a beep shortly after? This indicates what we call "A post" it means your processor, Video, and Ram all passed intitial tests to start your computer. If there is no beep dont panic as not all laptops do this. The fan however, if it does not slow down will indicate a hardware issue. This typically can be CPU, RAM, or Motherbord.
When your computer boots, does the screen stay completely black or does it boot past a splash screen and go to a flashing curser? This could indicate a hard drive issue. Usually repairable unless we hear clicking from somewhere in the device.
The last thing I would suggest trying is if you have a regular computer with a regular monitor, you can plug the monitor into the side of your laptop to see if the screen comes up on it. There may be a keyboard shortcut you have to press and if you let me know what model Acer laptop I may be able to help you with that as well.
Good Luck!
-Rogue
Jan 01, 2014 | Computers & Internet
When i press the power button the computer comes on but the screen stays blank three lights are flashing on and off one at the side of the caps lock button the middle light betweenn the power light and...
I believe blinking lights on the Caps and NumLock means that there is a problem about the Hardware, I've been a Tech Support for HP and those blinking lights are problems for Video Card, CPU, Memory.
It would be better if you call the manufacturer try if they can service your machine.
Hope it helps. =)
Apr 19, 2011 | Compaq Presario CQ62-215DX Laptop
I turn on my HP computer, and then I wait and the keyboard lights up and the keyboard works and all but the screen stays BLACK, and when I click the ''enter'' button, I know it enters onto the user, and...
Download either a Hiren's Boot CD (version 15.2), or a free version of Parted Magic (either or both on a CD instead of a flash drive ... because flash drives can EASILY be infected by malware and viruses! Set your BIOS so that the machine will not try to boot to the hard drive, but only to the CD. Then access your files via the OS on the CD, and copy whatever you need to copy off to another location.
May 16, 2017 | Dell InspironTM 1501 Notebook
Hello Experts, I have a HP Pavilion Tablet Laptop that won't boot. All keyboard lights and monitor lights (DVD controls) illuminate except the actual monitor, it does not come on and is completely...
I'm having the exact same problem on my less than 2 yr old HP Touchsmart tx2675 laptop. Could you please let me know if you have solved the problem?
Thanks and Regards,
Manish
Nov 01, 2010 | Computers & Internet
Blank screen, flashing keyboard, confusion
My Motorola Razor cellphone all of a sudden went blank, i took out the battery and put it back in and turned it on, but the keyboard just flashes and the screen stays blank, what do i do?
Jul 27, 2009 | Motorola Mobility RAZR V3
My Vostro 1500 will not turn on anymore...help please!
Reset/replace the Ram/memory. Sometimes faulty and failing ram can keep a computer from booting up. If you have 2 sticks, take one out and then try to boot, then try with just the other stick. The flashing caps lock icon means a general failure, though it is most commonly associated with the motherboard.
Jun 25, 2009 | Dell Vostro 1500 Notebook
Computer turns on but screen wont
most likely the laptop presentation mode is on. press the Fn key and the F5 key together (maybe several times) to take it out of that mode.
Feb 02, 2009 | Computers & Internet
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
HP Pavilion dv7-1129wm Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
