Question about HP Deskjet D2660 All-In-One InkJet Color Printer
HP D2660 printer- new. connected with USB cord. Software installed and ready to print. Printer makes a lot of noise, sounding like it's trying to move the paper through, but nothing happens. After a bit, it stops trying. Can't even print a test page.
  • HP Master
  • 11,800 Answers
In that case the printer is defective - take it back ASAP.
Posted on Aug 28, 2010
How to troubleshoot HP Printer not found during network driver setup issue in Windows Operating system?
Download the full feature software from the HP website or on the software disc and setup your printer for wired or wireless network connection.
There might be one of the following errors if the installer does not detect your printer after setting the connection type.
1.Printer not found
2.Devices not found
3.Unable to find the printer
During the Hp printer network setup, there may be some troubleshooting issues,
Step 1: Reset or restart your computer, HP Officejet printer and the router
1.Disconnect the power cord outlet from the router.
5465_install_1a-ur23imwvkexuk45mistkg3hp-5-0.gif 2.Close all the tabs running on your computer and shut down your computer.
3.Then turn off the HP Officejet 4650 printer.
4.After few minutes reconnect the power cord outlet to the printer and wait till the connected status light blinks to normal.
5.Then turn on the printer and computer.
6.Again install the HP driver and software.
Step 2: Check the status between the printer and the network connection.
Before the setup confirm that your printer is ready.
1.Wireless Network: On the printer, open the wireless network connection settings menu and check whether the wireless signal is turned on.
2.Wired Network: Check that cable is connected to the printer Ethernet port.
Note: The green light should be in steady status and the orange link should blink when the cable is connected and make sure that your HP printer is not connected to a guest or host network.
1.Set the band to 2.4GHz if it is dual band router else the printer cannot connect to the network.
2.Check the network name and status of the connection in the notification bar.
3.If it is a different network then reconnect your network to complete the setup.
4.Move the computer and HP Officejet 4650 printer closer to the router if the signal is weak.
5.Slide the Airplane mode to off if it is on.
6.And again try installing the software and driver.
Step 3: Run the HP Print and Scan Doctor:
1.HP provides a free tool called HP Print and Scan Doctor to resolve the scanning and printing issues.
2.Download the HP print and scan doctor software to resolve all the troubleshooting issues.
3.After the installation on the Welcome screen click start.
4.A new menu box appears on the screen with the printer list. If your printer is not listed then turn on the printer again and connect it.
hpscanprinter-ur23imwvkexuk45mistkg3hp-5-2.png 5.Click the option my product is not listed and then select retry.
6.After that, your printers display and select it.
Step 4: Temporarily disable firewall software.
If the firewall software is installed on the computer that will help you to block the threats that found on your computer.
Use the print and scan doctor to identify and temporarily disable firewall software on your computer.
1.Click network on the print and scan doctor window.
2.A drop down box appears in that select the option troubleshooting firewalls.
3.Click the firewall software to disable it.
4.And install the HP driver and software.
If the HP driver is successfully installed then consult the firewall software support to change the settings as security level, trusted zones. After changing the settings re-enable the firewall software.
If the HP driver is not installed then there is no issue in firewall software and re-enable it.
Step 5: Uninstall and reinstall the HP drivers and software.
1.Disconnect the cable if your HP Officejet 4650 printer is connected to the USB cable.
2.Click programs and features in the search windows.
3.A list of installed programs will be displayed click your printer name and uninstall it.
4.Then follow the on-screen instruction to complete the process and restart your computer and reinstall the software from the official site.
If you still have doubts regarding this setup you can call us @1-800-836-3987 or visit us 123 hp setup oj 4650
Jul 06, 2017 | HP Office Equipment & Supplies
Switching the printer on, it cannot print. the message was failed to print the document
-Restarting the computer and printer.
- Checked the USB cable.
-Check the printer spooler service is on( write "services.msc" on RUN, then check printer spooler is ready)
- Insert the printer cd and reinstall.
- after install restarting and print test page
Thanks and Regards
TRinoj
Aug 06, 2011 | HP Deskjet D2660 All-In-One InkJet Color...
My printer HP Officejet J4580 All in one, does not print, It reports "Entering sleep mode". Put new ink cartriges in, paper not jammed and no lights flashing and I printed a test page on the printer to...
Hi.
Try the following in order:
Disconnect printer power cord.
Turn off computer.
Disconnect computer power cord. (if laptop also remove battery)
Restart first computer than printer.
(this may look stupid, but it drains power that can jam USB ports and cause malfunction).
Clean the metal plate contacts in the ink carriage using cotton and isopropyl alcohol or cleaning solution.
Try turning off printer and performing a new cartridge installation. Use the HP software cartridge replacement procedure, do not simply swap cartridges.
Disconnect printer USB, reinstall printer software, connect printer back when prompted by setup wizard. Updated software for this model available at Software & Driver Downloads.
If you have spare cartridges, test them, the problem may be caused by a defective cartridge chip. Non original or refurbished cartridges commonly cause similar problems.
Sep 14, 2010 | HP Office Equipment & Supplies
How to install a hp printer d2660
Hi
To install a printer try the following steps
1. Connect the printer port to your system 2. Install the printer software CD provided at the time of buying the printer 3. After installing it will ask for a test page, give okay 4. Now your printer is ready to print.
Thank you
May 18, 2010 | Office Equipment & Supplies
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
How doi connect to my computer
Usb cable or wireless conect? For usb, connect the usb cable from the printer to a usb port on the back of your PC, windows should detect and install its own driver(add the software later), to confirm its connected, go to start menu > control panel > hardware&sound > printer. Should say ready or online under your printers name. If it says ready or online, try a test print, right click the icon and select properties, then 'print test page' at the bottom. If this works your all good to go., next install printer software if you haven't already.
Nov 06, 2009 | Lexmark X9575 InkJet Printer
Photosmart 1115 will not connect with a USB port
Was the printer new? Try it in another pc to make sure it's all right. Then try another usb cable. When you attach the cable, the pc should recognize when the printer is on.
Oct 23, 2009 | HP PhotoSmart 1115 InkJet Printer
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Deskjet D2660 All-In-One InkJet Color Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
