SOURCE: fuse for 1999/2000 ford focus diesel estate cigarette lighter
its fuse 46 and it should be a 15 amp according to the manual as i have the same car as you hope this helps
SOURCE: d cigarette lighter not workin, cant use sat nav or any 12v
Check to see if you have power to the fixture, make sure you have a good ground (fixture to dash tight), if all these check out you may have a bad fixture that needs to be replaced.
SOURCE: 2002 ford fiesta cigarette lighter not working
I have a Ford Fiesta Vetec 1999 the windscreen wipers dont work. Have changed the Fuse but when I switch car engine back on fuse just 'pops; again.
SOURCE: ford focus 2003 TDCI the
The fuse for tis lighter assembly has probably blown. Look in the fusebox for a blown blue color fuse. Replace this for a 20 amp yellow one. If you are powering items from this plug, it will need the extra 5 amp to cope. Hope this helps
