Question about Hotpoint Aquarius WF000 Front Load Washer
Remains full of water after macine gas wasdhed
  • 92 Answers
The water pipe must be sinking please double check and then call an engineer
Posted on Aug 28, 2010
The pilot light does not remain on when the button is released. While holding the button in and turning on the water no ignition happens. Gas cylinder is full. Please assist. Thanks! Mark
Your gas valve works in conjunction with a therm o electric valve it is a 2 stage operation. 1 is when you push it in and light the pilot. 2 is when you release the button. This prevents full gas to the burner and prevents ignition taking place if the pilot light fails. The thermo-couple provides a small electric current around 30ma which holds the therm o electric valve open and in turn keeps the pilot light on. The thermo-couple needs to be replaced, if it still cuts out then ths therm o electric valve which is a n integral part of the gas valve has failed and a replacement gas valve would be needed.
May 06, 2015 | Water Water Heaters
Soap water flows through the outlet pipe while soaking
are you referring to the drain pipe from the washer ? if so your drain pipe is mounted to low , it should be mounted so the elbow is above the level for a full load in your washing macine
Jan 10, 2012 | Whirlpool Washing Machines
Open flame remain out of the outlet manifold in the air shutter vent when i turn off the cabin switch of my suburban 6gl water heater
If flame remains after power shut off to gas valve, then the gas valve is obviously leaking by and can cause a very dangerous situation. PLEASE !! Shut propane off until that can be addressed.
May 20, 2011 | RTO Suburban Rv Water Heater Dsi Gas Valve...
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
The machine is not filling and all the display lights are flashing.Thankyou.
It sounds like ether youre plumbing is not leting water down the pipe or the valves have gone inside youre washing machine try filling the washing machine up via the powder dispensing draw with the front door of the macine shut and the macine off when the machine is full of water swich it to the program you want and see if it works if it does then its the valves in the machine burt before you do that unhook the filling hose from the wall and see if water is coming out if not its youre plumbing
Nov 27, 2009 | Office Equipment & Supplies
Water flow into washer will not shut off
It could be the valve or the fill sensor. You can Google the washing macine brand and it will give you a diagram of what parts the washing macine has and does Also try RepairClinic.com. .
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not fill with water
It sounds like the pull-out switch, under the pull-out knob, is not working and may need replaced. Go to Repairclinic.com and type in what your washing macine is not doing and they will give you hints on what to do next. But, it sounds to me like that is what is wrong with your washing macine.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Oct 21, 2008 | LG Washing Machines
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Over loaded the macine
Have you tried unplugging the machine for a minute to reset it?
Dec 09, 2007 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
23 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
