Question about Garden
I have 18.5 horsepower twin cylinder and when its cold its cranks and runs fine till it gets hot, then it goes spitting and sputtering and goes dead, and when it cools off it will run again
frcs68
  • 1605 Answers
SOURCE: 1978 Datsun/Nissan 280Z 2
go to zcar.com ask question there. you will get answer and what to look for.
Posted on Oct 12, 2008
fknstart
  • 404 Answers
SOURCE: truck spits and sputters when warmed up
do a compression test
Posted on Jan 05, 2009
  • 389 Answers
SOURCE: I have a 1995 chev lumina 3.1 engine. The car
It almost sounds to me like your EGR valve is full of carbon and not able to open properly so your engine is running rich.
Posted on Feb 22, 2009
  • 86 Answers
SOURCE: My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
Posted on May 11, 2009
  • 93 Answers
SOURCE: polaris ranger runs for a while gets hot shuts
Vapor locking? Check the fuel lines to see if they are too close to the exhaust manifold/pipe. Check for spark when it is hot. Be careful when pulling plug wire as to not get your hand burned.
Posted on Oct 14, 2009
Runs good for an hour then engine begins to sputter
Once it starts sputtering carefully pull a spark plug wire off (it can shock you) and see what happens. It sounds to me like you have an ignition module issue that once it gets hot it is grounding out and then when it is sputtering it is because you are running on one cylinder
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 02, 2013 | Garden
Running hot and using water also spits and sputters very bad on the top end
Check the inside of your combustion chamber and the inside of the rocker cover/ oil level. It sounds as if you have a blown head gasket.
Oct 06, 2012 | 2000 KTM MXC 250
05 taurus spits and sputters on startup when cold
This can be caused by a problem in the fuel pressure check valve of the fuel pump. Have a pressure leak down test run by a shop, if the system is losing pressure then the pump assembly must be replaced. The fuel pump is located inside the gas tank and is electric
Sep 19, 2012 | 2005 Ford Taurus
I have a suzuki xl.7 with the 2.7 v6 recently removed most of the intake to get to the egr valve to clean it all out and replaced gasket and reassembled everything now since doing so it will crank up if it...
i think you may have not put the timing right if you have changed the head gasket or removed the timing, make sure all timing is lined up on timing marks cams and the crank. adjust till they line up using piston number one as top dead. turn engine by hand (spanner on crank) and make sure they line up each time it goes to top dead on number 1.
Jun 23, 2017 | 2005 Suzuki XL-7
It runs fine in the summer when temps are warm, but when it turns cold,especially when you first crank it up, it spits and sputters and will not run. It like its not get gas
PUT A SCANNER ON IT AND CHECK THE TEMP READING FOR THE COMPUTER IT IS MORE THAN LIKLY BAD LIKE IF ITS 40 OUTSIDE THE SENSOR IS READING 90 SO IT DOESNT GIVE IT THE EXTRA FUEL IT WOULD NEED WHEN COLD
Oct 15, 2010 | 2002 GMC Yukon XL
1999 lumina 3100 spits sputters and backfires out throttle body
You need to get the codes read to verify,but i think your in need of coil pack or wires.
Oct 23, 2009 | 1999 Chevrolet Lumina
96 chevy 4.3 with 249000 km that just wont start
Have you confirmed fuel pressure at rail?
Sep 08, 2008 | 1997 Chevrolet K1500
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
