Question about Dryers
Operating manual for simpson clothes dryer model sirocco 350
huuum
  • 750 Answers
SOURCE: Simpson Sirocco 350 Dryer not heating
Check your vents are clear and the outside vent may have a cover on it to stop small animals from getting in it.
Take this off, if its even half clogged up it will stop the dryer from heating or it will heat unevenly.
And check the vent line is not kinked or twisted or squashed.
other wise it may be a bad heat element in an electric dryer.
Or a bad burner in a gas dryer.
Let me know what you find out!
huuum
Please remember to leave a rating
Posted on Oct 08, 2008
SOURCE: diagram of how to replace drive belt on simpson
Diagram of how to replace drive belt on simpson
Posted on Jul 31, 2009
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Posted on Nov 06, 2009
  • 40 Answers
SOURCE: Simpson Sirocco 350 Dryer cuts out after 5 minutes
Its probably NOT the sensor causing the problem. Have you checked the fan belt, that its not broken, come off the pulley or stretched? Put your hand over the airvent outlet at the back after it has been running a few minutes, if there is a lot of hot air coming out, then belt is ok. If not, replace the fanbelt with a new one, and problem will be solved. The sensor pops out because of overheating - usually because either the fan belt is broken or stretched, or the lint filter is blocked. Hope this helps!
Posted on Aug 20, 2010
Simpson clothes dryer sirocco 455 5kg the power shorts out when we turn it on ?
check the heating element.remove back panel to access it
May 31, 2015 | Dryers
Is it a big job to replace the heater element on the Simpson Sirocco 350 dryer?
It won't be the element unless a wire from it is grounding against the casing. You most likely have some sort of issue with the home breaker.
Mar 15, 2014 | Kenmore 500 6952 Dryer
Clothes dryer stopped working while it was working Simpson Sirocco 455, what could be wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 26, 2011 | Dryers
Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Jun 21, 2010 | Dryers
Nov 05, 2009 | Dryers
I have 2 simpson sirocco 350 dryers and neither will dry clothes as soon as a bit of heat happens they turn off is there something that I did'nt take out of them when Ifirst got them? Hoping you can help....
difficult one , but drier will typically switch off if the over temp. sensor activates. Suggest you move the drier away from the wall or any area that could block air flow into the air ducts and retest. Very unlikely both would do the same thing. Common denominator is its position..
Sep 14, 2009 | Siemens Dryers
When the dryer is on high or medium heat, it trips the power breaker of the house. it does not do this on air only/no heat", which makes me think of a short in heating unit.
the dryer is run by a universal motor, and these motors (while being very robust) can draw more current if the torque put on the drive train is overloaded. try running dryer with less clothes.
May 12, 2009 | Dryers
Mar 21, 2009 | Dryers
Condensation is forming on the walls when I use my clothes dryer
Simpson may have a kit available for accomplishing this. Also, your dryer may have several optional ways of venting.
Mar 27, 2017 | Dryers
Simpson sirocco 350 clothes drier
Yes fixed with prayers I found the restart safety switch and am now dring merrily,.Paste
Sep 05, 2008 | Dryers
Dryers Logo
1,229 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
