Question about SanDisk Sansa c150 MP3 Player
Playlist creation Hi. i need help. I am a canadian, and therefore cannot get rhapsody. is there any other program like it that will allow me to not only put music on my device (already have a program for that), but also organize songs into playlists? im getting tired of having to recreate my go list every time i add songs.
Well u don't have to use a program for putting music on to ur mp3 player it works like a flash drive so if u go to my computer and go into the device u can put music on like that and then put wat music u want in a playlist into it's own folder and right click it then click create playlist and just to make sure u have the songs in the right order double click the playlist icon and re-arrange as u want. BUT DON"T DELETE THE FOLDER! i have done that a couple of times, when u delete the folder it, the playlist is gone. anyways hope that helps u but if it doesn't email me at
Posted on May 08, 2008
Rhapsody downloads a few songs then stops.
if you want free songs and you have an email address watch this video
Oct 09, 2009 | Insignia Audio Players & Recorders
Creating Playlists for GoGear Aria 8gb player
If you want to make a new playlist for your 8 gig GoGear Aria, all you have to do is highlight the songs you want to add, then right click the mouse and choose create playlist. Name the new playlist then cut and paste it into "Playlist" in the music choices and there you go. No WMP needed.
Aug 18, 2009 | Philips GOGEAR SA6045 MP3 Player
The screen says" rebuilding the library, please wait"
Rhapsody (if that's the program you're using) uses a database file to store your library information on your computer (locally). Every time you sign into Rhapsody, this database must synchronize its contents with the Rhapsody servers. Sometimes your local Rhapsody database goes out of sync with the main Rhapsody servers, causing trouble with your library or playlists.
If Rhapsody is unable to resynchronize, you may get this error message. This error can also be caused by local database corruption or security settings blocking the connection to the server. To resolve this issue:
1. First, close Rhapsody, then re-open it and try again.
2. Try resetting your Internet Explorer privacy / security settings for Rhapsody
3. If that doesn't work, try resynchronizing Rhapsody with the server running a simple tool called dbclient
To run the dbclient:
Open My Computer.
  1. In the C: drive, browse to Program Files.
  2. Open the Rhapsody program file folder usually named 'Rhapsody'.
  3. Double-click the dbclient program in this folder (Vista users: right-click dbclient and select Run As Administrator).
  4. When the Success dialog box appears, click OK.
  5. Start Rhapsody and sign back in.
Let me know if this works
Hope this will FixYa problem
Jan 21, 2009 | Insignia NS-DV2G MP3 Player
Phillips 4gb Go gear playlists
ok heres what ya do.
connect to laptop/computer.
go to "computer"
find the player -- open it
internal storage -- open it
playlists -- open it
right click any of the playlists and click properties.
click the references tab.
go back to the folder called music in the device.
click and drag the songs into the window called references.
when finished click ok.
should work!
Nov 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
I Do Not Know How To Make A Playlist!!!
the insignia pilot came with a cd that has the best buy rhapsody music software. and you can make your playlists there
Jul 19, 2008 | Insignia Pilot MP3 Player
NEED HELP!!! Rhapsody Software Download Problem
Okay...MacAffee is causing problems with your connection and with the download/update. You will need to right click on the MacAffee icon in the system tray (bottom right of the screen) and open the program to turn it off (or just quit the program). Also make sure your firewall is down when doing this.
Re-install BBDMS (aka Rhapsody), and allow the update to happen. Once this is complete (assuming that MacAffee is the only anti-virus software running) launch the program, connect your MP3 player, and "authorize" the player on your computer.
This should take care of the problem.
I would also recomend a different anti-virus and firewall program. AVG isn't as invasive, and PCTools firewall will allow you to configure what programs are allowed to use the internet.
Jun 10, 2008 | Insignia NS-DV2G MP3 Player
Open McAfee -go To Settings - Firewall -disable
May 10, 2008 | Samsung YP-K3 MP3 Player
Cant play songs off my playlist
You can thank Microsoft for creating Digital Rights Management.
Okay...I'm assuming this is an MP3 that you loaded using the Rhapsody-to-go or other music service that allows for subscription music.
What the MP3 player is telling you is that because you have subscription music and not purchased music, the DRM allows you to only play the song or songs 30-90 days after download. To continue to listen to the songs, you will need to open your Media Manager software (Best Buy Digital Music Service, Rhapsody, WMP11, Media Monkey, etc) connect your MP3 player to the PC, identify the MP3 player through the media manager and tell it to re-authorize your tracks. Once its finished you'll be able to play your songs for another 30-90 days. You will need to repeat this re-authorizing to continue to play the tracks.
Apr 20, 2008 | Insignia Kix MP3 Player
Sansae200 rhapsody
If your device is indeed a Rhapsody branded version, the recovery tool you have WILL NOT WORK. You need to download the Rhapsody version firmware, located here; Then put the device into recovery mode: - power device off (press and hold power for 20 seconds) - slide the hold button into hold - press and hold record button while connecting device to computer (keep holding it until you see New Hardware Found on PC) Then "unzip" the software from the link, inside you will see PP5022.mi4. Open up My Computer, in there you will see 16MB format, drag and drop the pp5022.mi4 file into this drive. Unplug the device and allow it to restart. DO NOT PRESS ANY BUTTONS until it is complete. If the issue persists, try it again. It may take 3 or 4 tries. If that doesnt work, you need to format the device. Hit me back and ill tell you how to do that. Best of Luck.
Sep 09, 2007 | SanDisk Sansa e200 MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
132 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
