Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
Just wondering what the flow rate is Aquaflo XP2 Spa Pump 2.5hp. Reason I want to know is I want to use the pump as a circulation pump for a pool. thanks
  • 8,404 Answers
There is no way to know the flow rate of your installation beyond a guess ... I guess you are pumping about 95 GPM with a 2.5 hp motor ... a 2 HP moves about 75 to 80 GPM. A 1.5 moves about 60 to 80. There are lots of variables least of which are accessories in the line ... chlorinator ... heater ... filter and its cleanliness ... etc. Other vairables include pipe size ... distances water pumped, number of turns - fittings - restrictions, etc. To get a good idea of the flow rate (important to know when calculating 'turn over' rates) get and properly install a flow rate meter.
Thanks for your interest in FixYa.com
If you found this information helpful, the courtesty of a positive vote will be appreciated.
Posted on Aug 29, 2010
Flow master XP2 by aquaflo for spa; it clicks, but does not start. I could turn the shaft with a wrench, all plugs work.
the start switch has trash in it , use compressed air and blow out the back of the motor, this works most of the time for me. otherwise the motor will need to be dissembled and can be tricky do to easy to break parts. search your area for your local pool pump motor repair guy with free testing. and ahve him clean the switch
Sep 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My Spa needs a new pump. A Max E Pro Pump 2 speed was recomended but I found a Aquaflo Flo-Master Xp2 Spa Pump 1.5 Hp Two Speed which is new for about $400. less. Can I use the Aquaflo model just as well?
Yes, and I recommend and install them. Look at the voltage and Amperage information on both as well. It is typical to see 220V @ 12.9 amps. If you find this on both motors, they are the same size anyways.
It would take a while to explain, but motor manufacturers can rate a motor @ 1.5HP or 2HP and it can be the same motor. They use a rating called a "service factor" to screw around with the actual HP of a motor. But even if the 1.5 is a 1.5, it would be sufficient.
Jan 11, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
What windings do the leads of the capasitors get attached to for the flow master xp2
Please reply with the motor brand, model and serial number so we can get you an accurate wiring diagram. Simply comment on this post and enter the information there.
John
Dec 09, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am trying to find a replacement for ann XP2
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
106 people viewed this question
Top Aqua Flo Pool & Spa Experts
Ian Kime
Ian Kime
Bill Jordan
Jay Finke
Jay Finke
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
