Question about ASUS Eee 4G Notebook
Just got my EEE PC yesterday and I am unable to wirelessly connect to my router at home. I can connect to other wireless networks with the pc and my router works fine with with other wireless connections but when I try to connect with my EEE PC it says it is unable to connect. The router I have is a 2wire 2701hg-B model
  • 30 Answers
Have you put mac access control on your router, if so turn it off? is the router g or n or b compliant and does your pc match? have you set the right security wep/wpa/wpa2? if using wep you may need to not use the passcode but the key 1 which is generated from it.
Posted on Aug 28, 2010
Have Eee pc with windows7. wifi connection looses connection every few minutes.Network adaptor problem
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Sep 11, 2012 | ASUS Eee PC 900HA Notebook
Suddenly unable to connect to wireless network
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 02, 2012 | Dell Inspiron M501r Laptop Computer (AMD...
I can not connect to my home wireless router
make sure that wireless adapter is turned on. reinstall your wireless adapter drivers.
Apr 01, 2010 | ASUS Eee 4G Notebook
I just got my Asus Eee PC 1000H and the first thing I tried to do was to connect to the wireless network in my house but I don't have a wireless network icon. The wireless and bluetooth are both turned on....
I am assuming this has windows xp on it. Go to start settings/control panel then double click wireless network setup. Go through the wizard and go from there. If you need further assistance please let me know.
Thank you,
lee
Nov 13, 2009 | ASUS Eee PC 1000H Laptop
Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Sep 01, 2009 | ASUS Eee 4G Notebook
My wireless lan
Try toggling the wireless ON/OFF with special function keys:
<FN> + <F2>
If no broadcast available, check your router's wireless configuration.
Jul 10, 2009 | ASUS Eee 4G Notebook
ASUS EEE PC w/ Windows XP will not Connect Wirelessly
You need to know if your home network requires a password or paraphrase to allow you to connect. Also, you might have to check your settings on your router, they have to match the settings of your laptop wireless adaptor. You can try these solutions and if no luck post with more information
Jul 03, 2009 | ASUS Eee PC 900 Notebook
Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
ASUS Eee 4G Notebook Logo
287 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
