Question about Pioneer SD-P62A3-K 62" Rear Projection Television
Pioneer rear projection tv
When I press the power button the television immediately goes to standby and will not turn on. I can see the amber light on fromthe back
  • Godchannei Jun 22, 2008
    goes to standy by and won't play when i try to take it out of stand light come on for 1 second and goes back to red
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
Posted on Feb 16, 2009
It's the fuse on the bottom right of the back panel - there are 4 of them - one 5Amp 125 V, two 6.3 Amp 125 V, and one 4 Amp 125 V
I solved this by actually putting 4 fuses from radio shack at 6.3 Amp 250 volts!
I went through 2 packs of the 5 Amps and 4 Amps but these finally worked.
Good luck - I have never been a tv technician and have no experience in electronics- I just got sick of paying some guy $100 bucks to come out and change a .50 cent fuse in front of me.
Posted on May 19, 2009
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer rear projection tv in standby mode
if the relay clicks when pressing power check C258 in video assy.
Aug 14, 2007 | Pioneer SD-P62A3-K 62" Rear Projection...
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
343 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
