Question about HP LaserJet 1010 Printer
Hp laserjet 1010 printer without ant error it is doing paper jam evrt time wht is problam?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Try uninstalling then reinstalling the ink cartridge, if problem still exists consider visiting the nearest service center..
Posted on Sep 02, 2010
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Hi My HP printer is laserjet 1010 his problam is no take paper please advise me how to solve problem Thanks Ali
With just a few pages in the tray, send a job to the printer and at the same time look into the printer where the paper is. You will see if the paper pickup roller turns or not.
If the paper tray rises to where the pickup roller is and the pickup roller rotates then the problem is that you have a worn or dirty roller. The roller can be cleaned with a number of liquids but try warn water on a cloth first. Also if yiou take the toner cartridge out, you will have clear access to remove the roller or clean it. I have also removed the roller and then rotated the rubber tyre a little so that the worn part is not in use.
May 29, 2011 | HP LaserJet 1010 Printer
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Paper jam in hp laserjet 1010
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | HP LaserJet 1010 Printer
Stocked paper in my hp laserjet 1010
Depending on how tight or wrapped inside machine, You may try to open rear of machine and pull out the paper jam SLOWLY making sure you do not tear the paper where it can not be easy to get to.
Feb 12, 2009 | HP LaserJet 1010 Printer
Hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Nov 11, 2008 | HP LaserJet 1010 Printer
Paper jam problam
no the tefflon is not fitted properly as you again open the printer and clean the tefflons upper side as any of the greece substance is got stuck up on the tefflon to cause this problem.also clean the pressor roller of orange/red colour with the isoprophyl and then slowly rub the liquid with very dry tissue.your pressure roller is perfectly alright as this paper jam problem comes very often after the tefflon is changed if it is not fitted and cleaned properly.
Jul 02, 2008 | HP LaserJet 1010 Printer
HP laserjet 1010
more information needed to solve this problem icq 475653626
Jan 03, 2008 | HP LaserJet 1010 Printer
HP LaserJet 1010 Printer Logo
Seeker5211
Seeker5211
