Question about Toshiba Satellite A305-S6908 Laptop
Hi i have a toshiba a305 my windows vista when i make a recovery disk show this msg no hdd recovery area !! what i do plz help me
Bappa170873
  • 505 Answers
SOURCE: lost hdd password and systems recovery CD
click on the following link
http://www.pwcrack.com/harddisk.shtml
This gives you detail description of HDD pasword and from where to get it recovered
Posted on Oct 13, 2008
SOURCE: Built in HDD Password for Toshiba Portege S100-S1133
remove the rtc battery it's look like a bateery on the organizer its round and flat remove it then disconnect to remove the password
Posted on Feb 16, 2009
leecom72
  • 4806 Answers
SOURCE: Unable to create recovery disk.
Hi there.
Sounds like the software could be corrupt, but there is an easier way to create a recovery disk, check this tutorial out >>>>>
http://createrecoverydisk.com/
If you need more advice please feel free to post back.
Good luck and thanks for using FixYa!!
Posted on May 14, 2009
Jermzii
  • 106 Answers
SOURCE: toshiba a305 s6872, need to run recovery disk ,
I have a Toshiba as well, in order to boot from the dvd drive you will have to restart your machine, then when you see the Toshiba logo at startup press F12, you will see a small menu. Select your dvd rom drive from the list and press enter, if this does not work than there is still another way, keep me posted.
Posted on Feb 07, 2010
etaf
  • 779 Answers
SOURCE: need a toshiba portege R500 vista recovery disk
Toshiba Factory Reset
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
Posted on Apr 14, 2010
Toshiba A305 black screen
You can start by removing the HDD and testing, replace if necessary. Reseat the Memory Mods as well. Has there been any damage? Drop? I assume the blinking LED is the HDD?
Apr 26, 2013 | Computers & Internet
How can I restore my Toshiba L305D-S5895 laptop from the recovery disks when the laptop don't even turn on to windows or recognize the HDD? Please help or is the HDD wiped clean somehow? I have windows...
You should be able to boot the computer from the operating system recovery disk. Most likely your harddrive crashed, or one of (many) other issues. It could have just erased your MBR, in which case you can boot with a live cd and recover most (if not all) of your data.
Jun 15, 2011 | Toshiba Satellite L305D-S5895 Notebook
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
I bought a Toshiba laptop satelite T135-etc I'm trying to make recovery CD, but when I open the recovery media Creator; appear a message which tells no hdd recovery area! \the toshiba recovery disc...
The recovery partition has been deleted somehow. You cannot create a recovery cd on that machine.
Sorry.
P.S. That partition isn't hidden...many think it is.
Again...sorry. Hate to be the bearer of bad news.
Good luck
P.S. You might consider using a program like Clonezilla to make a copy of your drive. Or do a fresh install.
Oct 16, 2010 | Toshiba Satellite A305-S6908 Laptop
No hdd recovery area!
have a look at this link and see if it helps you out. No hdd recovery area Google Search
Oct 13, 2017 | Toshiba Satellite A305-S6908 Laptop
Satellite L305-S5921 (again)
There is a greater chance that you have a bad HDD (hard drive). Since the Recovery image is in the HDD, you still need the recovery disc.
Replace the HDD and run full system recovery using the discs.
Hope this helps.
Dec 21, 2009 | Toshiba Satellite L350-ST3701 Notebook
NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Oct 06, 2009 | Computers & Internet
I use toshiba satellite A305-S6872 laptop would not load OS
you will most likely have to go into the recovery console to fix the problem or even re-install.
The other two solutions are to either boot up in safe mode to correct the problem by trying to revert back to a saved well working time, or take out pci cards and reboot always taking out another pci card until you find the problem.
if nothing works, re-install or fix in recovery console. <<< or >>>
BEST Solution
at re-install, choose repair windows.
Aug 24, 2009 | Computers & Internet
Im getting an error code 08-0E89-0000 how do i fix this I had Toshiba A305-6844 after removing all the partition from the HDD using Recovery Disk I get Error #08-0E89-0000 while recreating the partitions...
I had the same message, replaced the hard drive, still got the same error code, took the hard drive back to best buy and they game me a new one, put it in and got the same message again...
Jul 02, 2008 | Computers & Internet
System recovery
Hi
Please go into my conputer and check whether u have a recovery partition or not..... If you have... restart your system and tap on F11..... go to recovery partition... U'l get a pop up to create recovery cd's.... Plz create the cd's once u get the pop up
Oct 22, 2007 | Computers & Internet
Toshiba Satellite A305-S6908 Laptop Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
