I have a Durabrand ADB2737BD VCR-DVD Recorder (2007) It made a strange "pop" noice, now it will not power up.. Power supply is OK, Fuse in Plug is OK.. Please help...
SOURCE: tv won't tern on
dont know how to tern on a tv, I do know how to TURN on a TV though...
Posted on Jul 27, 2007
likha
  • 790 Answers
SOURCE: no power
the problem is the power section Hot and Cold area. maybe you have defective fusibul resistors or in the oscillation circuit thats why your tv cant turn on automatically.
Posted on Sep 28, 2007
SOURCE: MODEL#DRT-S810 DVD RECORDER/VCR COMBO
The DVD recorder is like a PC internal drive. Pull the 4 pin molex connector and check the voltages across 1&3, 2&4. Should have a (+ or -) 5volt, and (+ or -) 12volt (you can compare with a PC's voltage across the same kind of connector if you want). If you don't have a 5 & 12 volt reading your power supply is probably bad. Optionally confirm DVD recorder works by removing and attaching to a (spare?) PC.
Posted on Oct 30, 2007
  • 61 Answers
SOURCE: HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
Posted on May 15, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Sep 19, 2008
Does The Magnavox Dvd Recorder / VCR zv427MG9 Have An In Line Fuse
There is a replacable glass cartridge type fuse inside it. It can be located at its mains power supply regulator board.
Jun 09, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
My dvd player is dead.
You check the SMPS (Power Supply Section) and verify the voltages from the various terminals of the transformer accordingly check the bridge, voltage regulator, and filter circuits. If any of this parts are gone replace the appropriate parts not the all.
Jul 25, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic dmr es30v
Without seeing the actual unit, I would guess that the power supply has failed. These unit have what are called "switch mode" supplies that rely on circuits that oscillate. If a capacitor goes bad, the unit won't oscillate properly, thus no power. These are difficult to track, but are not usually expensive to repair. I would suggest a trip to a service center for a detailed repair estimate. Report the results here.
Dan
Jan 31, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
No power
1. Check that the AC outlet is working.
2. Check that the AC power cord is ok with no damage.
3. Unplug the unit, remove the cover and check for a blown fuse.
If blown, replace with a value that is the EXACT value as the original.
4. If the fuse blows again or the unit is still dead, you most likely have a problem in the power supply section.
In that case, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Mar 19, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Power not on
try changing the fuse inside look at manual for reference good luck
Jan 30, 2008 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
