Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Door wont latch - Hotpoint 24 in. FDW60 Free-standing Dishwasher
  • Hotpoint Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
    Scholar:
  • 195 Answers
Easy fix you can order parts online and then turn off the power and open the door , remove all screws on door and pull the panel up and back , to look at the door latch , this latch also has a few wires on it so you need to remove the little micro switches that the wires plug into. this is also very easy to do, when you go to ored the latch you will need the make, model ans serial number to get the correct latch should be a very easy fix just take you time removing the micro switches they brake easy
Posted on Oct 28, 2011
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Back door wont open
door latch is jammed. the door panel will get damaged most likely during removal then latch will need to be opened some time a air chisel is needed to bust latch apart take to shop to have repaired if you dont have the tools.
Aug 19, 2012 | 1999 Audi A2
Vw 2.0tdi the passenger door wont open from outside and wont always close??
Take off the door panel and check to see if the linkakge from the outer handle to the latch has become disconnected and for the closing problem lube the latch well more than likely its not opening fully when you pull the door open so when you go to close it it pushes the latch closed before the actual bar its suppose to latch to enters the latch
Dec 31, 2011 | Cars & Trucks
1999 Nissan Pathfinder 4WD 3.3l. Rear door wont
Cut where the latch connects with a sawzall. Replace latch post whee the latch articulates.
Jun 28, 2010 | Cars & Trucks
Push door and it justs wont click shut moved swinging arm in door with screwdriver but wont lock
if it wont lock that means that its broken replace the whole latch. its easy just take the door panel off then take the linkages off the latch take out the two or three screws holding the latch on and pull it out. than reverce those steps when installing the new latch.
Jan 04, 2010 | 2006 Ford Focus
Driver's side door latch wont open door from inside
Go to http://www.hmaservice.com/ and register (vehicle by VIN). Afterward, you'll have access to technical information (manuals, wiring diagrams, service bulletins, etc) about your vehicle.
Jul 16, 2009 | 2003 Hyundai Tiburon
When i try to open the door it wont move the bottom latch releases but the top wont and i cna get to it to try to remove it
Section 501-14A: Handles, Locks, Latches and Mechanisms 1997 F-150, F-250 Workshop Manual REMOVAL AND INSTALLATION Latch, Rear Door — Upper Removal
  1. Remove the rear door trim panel; refer to Section 501-05 .
  1. Remove the rear door radio speaker.
    1. Remove the four radio speaker screws.
    1. Disconnect the electrical connector.
  1. Carefully peel off the rear door watershield.
  1. Disconnect the upper rear door latch cable.
    1. Lift the clip.
    1. Pull to release the cable from its seated position.
  1. Remove the upper rear door latch.
    1. Remove the three screws.
    1. Pull the upper rear door latch and the cable up through the door latch opening.
Apr 14, 2009 | 1997 Ford F150 Regular Cab
99 cavalier drivers door wont latch without force
If there is no resistence to the latch then it will have to be replaced.
Feb 15, 2009 | 1999 Chevrolet Cavalier
99 ford explorer door wont shut
sounds like the door latch has triped while the door was open.the door is held closed when the latch grabs around the u shaped bracket you can see when door is open.make sure door is unlocked then with a screwdriver or even a pen stick it in the door latch and slide the latch over to reset it.
Nov 14, 2008 | 1998 Ford Explorer
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
460 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
