Question about Mini Lb X 0.1 Grams Digital Pocket Jewelry Scale Scales
I own a mini gram scale. it is a pro scale lc-50. im recilabrateing as the user manual tells me how and its says fail instead of pass.. how do i fix it?
How do I change my 100 gram weigh max scale from calibrating at 50 grams back to 100 grams?
a scale is calibrated at half it's capacity. when you use a 50 gram weight to calibrate it, it can still measure 0-100 grams properly.
Aug 15, 2014 | Measuring Tools & Sensors
How to delete all contacts and clear phone
Hi leanne_maree...
Go to the following webpage and download your user manual for your Xperia.
Please take time to rate me
Bud
http://www.boeboer.com/sony-ericsson-xperia-x10-mini-pro-user-guide-manual/
Oct 08, 2012 | Sony Ericsson Xperia X10 Mini Pro U20i...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Jun 25, 2010 | Microwave Ovens
What is 4lbs 12oz in grams
Considering 1 lb is 453.59237 grams,so...
4lbs is approx. 2153.75 grams.
Oct 11, 2009 | Conair Weightwatchers Body Fat Scale 4...
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Sep 08, 2009 | Health & Beauty
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
Equinox EX-300 Digital Scales OUR2 comes up on the screen when i turn it on
turn on your scales press and hold mode until cal flashes up the press and hold again until 100.0 flashes then put a 100 gram weight on it then will say pass if you havent got a 100 gram weight i used 14 2pence pieces and and a penny and thats it mine are working spot on now you can repeat the above when you get a 100 g weight but the coins are more or less **** on
Aug 14, 2008 | Computers & Internet
Mini Lb X 0.1 Grams  Digital Pocket Jewelry Scale Scales Logo
137 people viewed this question
Top Mini Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Mini Measuring Tool and Sensor Expert? Answer questions, earn points and help others
