Question about Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher
We have an error message on our Bosch Exxcel dishwasher - h24 - which doesn't appear in our manual and we wonder what we need to do to rectify it. The dishwasher will not function. The last programme selective was Intensive 65. Martin Donachie
  • 3 more comments
  • kim tyson Mar 30, 2012
    I also received an h24 code on my dishwasher - I know this is late for the thread opener but - to get around it initially, hold the start button for 3 seconds which will reset the washer and allow you to continue.
    After that, the only code in the manual that comes close is E24 which means the outlet hose is kinked - leaving a bit of water in th dishwasher. If it (the code h24)doesn't come back it probably means some water was spilled into the dishwasher before startup and the sensors thought it was not emptied properly. If it comes back, call Bosch for warranty.
    Solution:
    I also received an h24 code - not H24, but h24 - on my dishwasher - I know this is late for the thread opener but - to get around it initially, hold the start button for 3 seconds which will reset the washer and allow you to continue.
    The only code in the manual that comes close is E24 which means the outlet hose is kinked - leaving a bit of water in the dishwasher. I know that close only counts in horse-shoes and hand-grenades but there was water in the bottom of my dishwasher. I re-read the entire manual and believe h24 means 24hour delay - which can be accidentally triggered via hitting the "-" button once - or the "+" button 24 times. So the 2 ways to reset it are to hit + or - until it says h00 or the reset mentioned above.
    Funny thing about the Bosch diswasher is that it doesnt say any where (obvious) model#=xxxxxxxx. There are many numbers on the manual and washer itself but no clue as to which one is the model# until you bring out the CSI forensic equipment and find it using UV rays on the inside leftish top of the front door. Model#=SHX58E15UC/01. By the way, that scheme gives 3,089,157,760,000 possible models - before the /01. Really? Is that necessary? As for the code - Couldn't they have simply had a display or light that signals delay is on?
  • jess_joel
    jess_joel Jul 10, 2013
    Thanks Kim Tyson ! I had the same problem & fixed it by pressing the - button :-)
  • Kathy Spreadborough
    Kathy Spreadborough Nov 11, 2013
    Thanks so much I just had the problem was looking for a solution and found your thread thanks so much
  • Celia
    Celia Aug 21, 2014
    Thank you for your advice! It worked, I held the start button down until it kicked in. It had 1 minute left from the previous cycle, so when it stopped I turned the dishwasher off and then back on. The dishwasher was then ready to start another load. Phew!! Not sure what I would do without it! Appreciate your advice, my guess is my little one has pressed some of the timer delay buttons. :o)
  • Bosch Master
  • 19,396 Answers
Hi Martin.
There is no Error H24 on Bosch machines. What the display is trying to tell is H2O, incorrect displaying may be caused by defective LCD display or board.
H2o is displayed when there is an inlet problem, either because water pressure is too high, too low, inlet hose is kinked or blocked, inlet valve is devective, or pressure switch is defective.
If you get problem only when selecting Intensive, which requires higher water pressure, then the problem can be pressure from the house lines, inlet valve blocked or pressure switch.
Let me know if this helped, in case do not forget to accept.
Regards.
Ginko.
Posted on Aug 28, 2010
Hi, just had the same issue. In my case it could be fixed by deactivating the Childproof button lock. Press button B for 4 secs until CL is off (upper left square button), then reset (press start button for 3 secs) ...
Posted on Jul 03, 2013
Instruction manual for bosch exxcel dishwasher
Hello hazenchris
Please click the link below to download the user manual for the Bosch SRS45E02GB/18.
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qcbpLlccdcso0pdmdb---03K&UMOBID=qcbpLnecdcso0pdmdb---03K
You will need to have Adobe Reader or another PDF file viewer installed on your PC to view the manual:
http://get.adobe.com/uk/reader/
If you need assistance with your Bosch dishwasher, please let me know.
Regards,
BElectric
Oct 17, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Bosch Exxcel dishwasher wont clean properly?
the cleaning section is mostly from the circulation pump. is the pump is not working it has to be replaced .go to sears partsdirect.com and check out part first,. this will let you know the prices to fix or replace. then call ten repair person and find the cost to change the circulation pump.
Mar 13, 2010 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Error message E06. Will not start . Bosch Excell dishwasher. Only 6 days old
This error code is the door mechanism or the electronic panel. Mine also had it within days of purchase, got fixed. Seems to have shown up again.
Dec 28, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Exxcel Max USER MANUAL
hi there,
if you send me your e-mail address, i will forward you the file in .pdf.
thanks,
c
Oct 23, 2008 | Dishwashers
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
4,084 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
