Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
What does "Ventilate" mean please? It has appeared in my machine's message window. Thanks very much.
  • Gaggia Master
  • 1,711 Answers
<b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">We have a useful tip here in this link which can help you</span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"><a rel='nofollow' href="http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime">http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime</a></span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt"> </span></b><br /> <b><span style="FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 12pt">Good luck</span></b>
Posted on Aug 28, 2010
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Oct 19, 2014 | Gaggia Titanium Espresso Machine
HELLO THERE IN MY MACHINE APPEAR THE FOLLOW MESSAGE CARCAR CIRCUITO (IN SPANISH) WHAT DOES IT MEANS?? THX VERY MUCH
It means clear the water circuit or ventilate. Run the hot water cycle for a fer seconds that should clear it.
Aug 02, 2010 | Gaggia Espresso De Luxe Espresso Machine
What does ventilate mean?
"Ventilate" simply means that there is an air pocket caught in the system and running water through it can fix the problem. When the ventilate message appears, you will need to run hot water through your steam/hot water wand as if you were going to fill your cup with hot water. If the message does not go away after doing so, you will have to run hot water through your wand continuously into an empty container (emptying one full water reservoir if not more). Once your display screen reads "Select Product, ready for use," you will be ready to brew delicious coffee again.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | Gaggia Syncrony Compact Digital Espresso...
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
What do you do about the ventilate message
Ventilate is the same as priming the machine open the hot water valve to purge the hydrallic system.
Jan 24, 2010 | Saeco Magic Comfort Plus Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
2 messages: descale, and ventilate plus no hot water only steam
descale you need to use special descaler not vinegar vinegar is not strong enought and remove calcium in little piece that might block elsewhere descaler melt calcium 1 part water 1 part descaler fill the water container start machine open side valve for few second turn it off wait 15 minute repeat untill empty after rince very good that stuff is corosif go in thr menue reset the descaler mode and voila !
THANKS FOR USING FIXYA
FROM MONTREAL
CANADA PIERRE
Feb 18, 2008 | Saeco Royal Professional Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
48 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
