Question about Nikon Coolpix 5000 Digital Camera
When it tun the camera on i either get a system error warning or a remove lens cap warning. Obviously the lens cap is off. The lense is not doing the normal start=up movments.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Help me in finding Lens cap online for photography, where should I check for the same?
Lens caps come in different sizes to fit different size lenses. Obviously, a big lens requires a larger cap than a small lens.
Two of the better online sources for just about everything photographic are http://www.adorama.com and http://www.bhphotovideo.com
Jan 10, 2014 | Cameras
Lense stuck out, cap error message
try to take out the battries for like 5 minites and so on if there is no obstuction with the lens there will be a fault in the camera and will be difficult too relace your self its better off sending it back as it seems the sensor inside for the lens is buggered thanks from chris plz rate
Sep 24, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
Error 99 all the time , 1 yr old ...started it about 2 months after i bought it
Hum, error 99 eh? Canon's catch all error code, there is a ton of little entities that can cause error 99 from using third party lenses, batteries and even grips but, it all comes back to an electric contact fault. By using a good clean new pencil one with the red rubber eraser most of the error 99 problems can be quickly for lack of words erased. The most obvious problem area if you camera is not fitted with a battery grip is the lens contacts between it and the body of the camera.
Remove the lens, put the body cap on the camera when you are doing this part and while holding the lens as vertical as possible with the contacts down lightly rub the cold contacts. You can use a lens tissue and blow bulb/puffer to remove loose rubber. While you are at it clean all your lenses and put the rear lens cap on while not in use.
Okay the body, it's not as easy but doable, remove the body cap keeping the lens mount and open cavity pointing downward. Lightly rub the body contacts well but also gently, clean any rubber away from the contacts using a lens tissue. Don't use the bulb/puffer as it will blow eraser dust into the camera and possibly cause flecks of dirt to adhere to the sensor.
Once clean reinstall your lens and go do some photography.
Other things that cause this annoying error 99 are grip contacts, battery and recently I got into an error problem and my fix was updating to new camera firmware. That problem took me while on an assignment and would have been embarrassing except my back up was a "Rebel". Winding down the shoot the Rebel started with this error 99. Once back to the studio I did the updates and cleaned every lens I had. Cheers Happy New Year have fun make lots of pictures.
Jan 02, 2011 | Canon EOS Rebel XS 35mm SLR Camera
LENSE CAP WARNING STAYS ON EVEN WHEN IT IS REMOVED?
Mine went back to JVC because it was a design problem. They fixed it for free.
Sep 20, 2008 | JVC Everio GZ-MG130 Camcorder
When i tun it on it says lens error!??
Seems your camera gone mad and needs Electronic Doctor immediately. :D
Jul 31, 2008 | Canon PowerShot SD600 Digital Camera
FZ18 Lens Cap error message with telephoto converter
I have the same camera, and had the same problem. Make sure the camera is switched off. Then take 2 hard pieces of plastic with sharp ends. Carefully try & jam the outer ring with one, and try turning the converter with the other. I used a mini screwdriver, and left some marks on my camera. Thats why I recomend using plastic of some kind.
When you use the converter, switch off the battery saver in the camera. That way the converter won't jam again, as the camera won't switch off automatically. There is also a programme in the menu that is used for converters and external lenses. It also prevents the lens from retracting completely.
Hope I have helped you.
DaveSA
Mar 21, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
Warning Lense Cap On
This will sound crazy, but I just read the section under "Tips and Tricks" entitled, "Freezing". Users there recommend dropping the camera (gently) about an inch down onto your mousepad, or squeezing the casing of the camera, expecially around the battery. I squeezed the camera around the lens and Viola!, no more problem.
Nov 09, 2007 | Nikon Coolpix 885 Digital Camera
Nikon Coolpix 5000 Digital Camera Logo
139 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
