Question about Hotpoint Dishwashers
Latch on door wont alow door to close - Hotpoint Dishwashers
  • Hotpoint Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 29, 2010
Door wont latch
FIX CAR DOOR LATCH - YouTube
? 1:29
https://www.youtube.com/watch?v=wmWsM-TSaKo
Oct 21, 2011 - Uploaded by benherrerajr
Ever had a car door that wouldn't close? If the latch was accidentally stuck down, then here's the most ...
DIY Fix & Repair For Car Doors That Will Not Close
finley.xyz/diy-fix-repair-for-car-doors-that-will-not-close/
You are out and about and your car door suddenly won't close and stay shut. ... should be your first go to choice for repairing a car, truck or vehicle door latch of ...
Car Door Won't Close or Stay Shut - JamesMaurer.com
Jan 16, 2016 | Cars & Trucks
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Door wont latch shut
while holding the door handle up to open try to separate the fingers in the door latch if they wont separate.. the rods inside the door may have broken loose from the mechanism..this requires removal of the inner door panel to look at..
Dec 23, 2013 | Mercury Sable Cars & Trucks
Tailgate door wont latch
IT sounds like you closed the Trunk/ Liftgate with the Latch partway closed. Lube the Latch and hopefully it is not bent. If it is not latching, you can try and ensure it is aligned propery (use a piece of Tape and see where it is hitting the STRIKER...
If not, you are going to be replacing the Latching Mechanism.
Apr 06, 2013 | 2009 Honda CR-V
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Vw 2.0tdi the passenger door wont open from outside and wont always close??
Take off the door panel and check to see if the linkakge from the outer handle to the latch has become disconnected and for the closing problem lube the latch well more than likely its not opening fully when you pull the door open so when you go to close it it pushes the latch closed before the actual bar its suppose to latch to enters the latch
Dec 31, 2011 | Cars & Trucks
1999 Chevrolet Venture Power sliding door opens back up after closing. I have cleaned the contacts on the door post and on the door itself. There is nothing in the way, ie: weatherstripping or seat belts....
simple door latch, try unplugging the power and see if the door opens, if it does its not the motor. if the door is out of alignment it wont latch. if the latch in the door is broke it wont latch. try locking the door when its closed.
Mar 06, 2010 | Chevrolet Venture Cars & Trucks
Front door latch jams and door wont shut
It sounds like the jaws are close. you need to pull on the door latch lever and hold it open use something round like a punch. not your finger. and open the jaws. if the door latch is not bad your door should close and latch normal.
Feb 25, 2010 | 2004 Chevrolet Aveo
Door Latch will not engage
It sounds like one of the door handles is not returning alowing the pawl to latch, Lubricate, the latch assembly, making sure you work the inner and outer door handles. Also roll the window all the way down, and look down through the slot to see if you can get some spray lube at the back side of the latch, if so lube again while working the handles. Spray the pivot pionts and sliders on the handles.
Hope this is of some help.
Ed
May 08, 2009 | Volkswagen Golf Cars & Trucks
Is there a dl code? If not note the door striker position as the door closes. If you have to push it shut you need a door lock and if the striker is hitting below the latch too much a hinge will fix it. Finally look for a black pin above the striker for any damage as the latch will need to be replaced if broken too. Because with this and a door hanging low will not close the circuit and the ccu will believe the door is open also.
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
47 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
