Question about Whirlpool LER4600 Electric Dryer
Whirlpool Electric Front Load Dryer
Dryer does not spin, although motor sounds like it is getting power.
  • Jonathan45 May 07, 2008
    Thanks! I'll check it out.
  • Anonymous Mar 31, 2014
    Dryer not spinning but motor is running
  • 487 Answers
This can mean 2 or 3 things.
Fist of all your drivebelt can be worn or lose Pleasec check.
Your bearing can be gone or your motor is broken.
Chek if motor runs witout the belt.
Please check this LINK for drawings and parts
Please rate me if this worked for you
Posted on May 07, 2008
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F7 error message when using my Whirlpool Duet electric dryer and then it just turns off
F07 Motor Control Unit Error
Description: The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Check or Repais:
- Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
- Check the MCU
- Check the Drive Motor
- Check the Wire Harness
Hope helps.
Sep 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool electric dryer. The motor, thermal fuse, and control panel have been replaced. The door switch functions properly. When turned on, the controls operate and timer counts down like...
Sounds like a problem with the control panel wiring (wire(s) connected to wrong place(s)), although the control panel could be faulty. I would first carefully check all the wires at the back of the control panel against the dryer wiring schematic.
Dec 24, 2017 | Whirlpool GEW9200L Electric Dryer
Whirlpool Electric dryer won't start
Your problem sounds like it could be a broken belt, faulty motor, or maybe the belt has slipped off of the motor or idler arm pulley.
You can try this first:
Uplug the dryer, reach inside and try to turn the drum 1/4 to 1/2 turn, the plug the dryer back in, and push the start button. Sometimes motors will get dead zones in them and this will move it from that zone.
If you attempt the repair, and if you have a front loading machine, you would remove the front of the machine, this will expose the drum and belt, you can now check the belt to see if it is ok. If it is ok, then you can remove the drum and belt and this will expose the motor, idler arm with pulley and drum rollers.
While you have the drum out of there it is a good time to check the condition of the drum rollers to see if they have flat spots on them, if they do have flat spots on them, then need to be replaced. If not then I recommend that you lubricate them at the shaft with a good grade of Machine Oil such as 3 in One oil. This will save problems later.
Good luck,
I hope this helps you
Oct 04, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Duet Front load dryer
Normally this condition is caused by a broken belt...or a burned up motor
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool elec dryer starts when button pushed, but stops when button released . Has happened before, but seemed to solve itself.
There is a centrifugal switch on the motor that maintains power to the motor if the motor is indeed spinning and the belt intact. If your belt isn't broken, check the switch.
Jul 14, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer not spinning.
Sounds like the motor is not getting to proper speed. As long as you check for things in the blower housing and bad idler and support bearings before buying a motor. It could be motor bearings or weak windings. Replacing the motor is not a simple task and involves removing the front and the blower. Make sure it is the motor as most places will not take returns for electrical components.
Eric
Jul 06, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LER4600 Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
