Question about Canon LASER SHOT LBP-2900 Printer
While printing a black line appeared in the sheet and also paper scratched
  • Canon Master
  • 17,130 Answers
It is possible that the paper is getting caught up while in print.
Please rotate rollers manualy and clean after removeing the top panel and the drive link.
Usea good swab to clean out the rollers , any dirt or lodged paper in the movement track.
check if the rollers are damaged or the movement is irregular.
Use good lighting to check , clean properly and see for change if so repeat till the fault clears.
Need not open out rollers unless you detect some changes in the arrangements
Posted on Aug 28, 2010
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: mp530 model I have a heavy black ink line
Thats because the ink is overflowing the ink absorber and coming up thru the bottom of the machine. You need a shop to replace the absorbers and install a mylar shield so that doesn't happen again.
Posted on Aug 10, 2009
When printing black dots appear chaotic, over the entire sheet of paper. What to do?
If the black dots appear on every sheet of paper it could be the fuser unit is wearing out or the drum unit. The way to check that is to stop a print half way through and remove the paper. If they are not there before the fuser unit but after it then it will be the fuser. Or if they are there before the fuser unit it will be the drum unit. If it they only appear specfic to one source then it is likely to be the source of the document. IE copying - check the optical area (scan glass etc). If on incoming Faxes it may well be the sender that has the problem and is just transmitting them to you. Hope this helps.
Sep 09, 2015 | Canon iRC2380i
My fd100 wont print but thinks it is. also some times it freezes
if you could check the paper that you are using. make sure thermal. also scratch the paper, if a black mark appears this is the side that goes down in the paper holder, if you don't see a black line you don't have thermal paper. also make sure it is credit card machine and not adding machine paper. if you have another roll try that one. if persist. make sure the paper is hitting the thermal reader. there is no ink
Jul 17, 2014 | FirstData First Data FD100 Thermal Paper...
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Line is appearing on the printed copies. How to
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Dec 07, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Not sure how long we've had the PCR-T265, but trying to set it up. Acts like it is printing but nothing shows up on the thermal paper. Thoughts?
You may have the paper loaded back to front. If you scratch the paper quickly with a finger nail, you should see a black line appear. if not, try the other side of the paper. The side which turns black should be facing you while you are in front of the machine. --------------------------------------------------------------------------------
For those of you who need / looking for a Casio PCR-T265 manual, http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Aug 09, 2010 | Casio Parts Cash Register PC Desktop
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon LASER SHOT LBP-2900 Printer Logo
88 people viewed this question
old marine
old marine
