Cannot access the stored data (folders) in my kingston 8gb pen drive
  • 864 Answers
There is generally a lock on most thumb drives make sure the lock is in the unlock position. If this isnt the case please download this program click here for check flash. This program is called check flash. It will help you verify that the flash drive's memory isnt damage.
  1. To commence testing, run check flash. Select the voice recorder drive (this will be the same as the one you checked in properties) concerned in the ‘Drive’ combination field. Retain the ‘Use temporary file’ as the ‘Access type’ settings. Only the ‘Write and read test’ action is available for this type.
2. Also leave the ‘Small pattern set’ option as it is. Thus configuring, a complete test cycle consists of two test runs with different data. This is sufficient for a flash device.
3. If you want to do a thorough check, select ‘Full pattern set’. The tool then conducts 18 test runs for every single bit to check its functioning but this takes quite some time. To start the same, click ‘Start’ and wait for the analysis to complete.
If you still cant use the device after this please let me know and you may have to format the device but im assuming the lock is on. But if check flash says everything is fine then you should be able to recover the data. Please let me know by updating what happens in a comment so i can help assist you further. Thanks, Midwest-tek
Posted on Aug 28, 2010
Dt101
use this command in command prompt to find the data
attrib -s -h -r /s /d
May 12, 2013 | Kingston datatraveler 102 - 8gb usb 2.0...
I have password protected KINGSTON data traveler 101R and password window is unable to open an error window occur in secure MFC APPLICATION
Click start click on computer to open you should your drives
C: usually your hard drive D: or E: your cd/dvd drives if you have 2 and your usb drive possibly E:or F:
Click on your usb drive right click in it select new folder option you can name it
Then put all files or data you want to password protect
Right click on the folder select properties then click sharing tab tick in make this folder private box
Another message might appear you do not have a password on this account click yes
User and password account will open for you to put in place a password
This might vary depending on your operating system in XP
Select properties then security tab at learn about access controls at the bottom of the box
Also another option to change permissions click edit
Then click deny then click apply in W7
also you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-safeguard-free/3000-2092_4-75115673.html
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
hope it helps you
Jul 09, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 8gb pen has malfuntioned
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | Kingston Digital 8GB DATATRAVELER C10...
How can we repair a USB which is crashed like a hard disk.
Dear i have send some information of solve your problem. I hope you have satisfied my suspicion if you can solve your problem you can read this information
Thanks.
Pen drive is the best way for people who are looking for larger space to store their important data and want a compact, easy-to-operate storage drive. These pen drives are mainly trendy among system and network administrators. They can load a large amount of information about configuration and software that can be used for the system maintenance, recovery and troubleshooting. But what if there is a problem with your pen drive having important documents have been crashed? Ddipr.com releases new USB repair software to ensure user to get back files and folders stored in USB pen drive.
Pen drive data recovery software securely restores lost digital images, office documents, database files, audio, video files etc from your damaged and logically crashed USB pen drive.
Ddipr provides advanced and professional USB repair application to recover missing or erased files and folders lost due to accidental deletion, virus attack, software malfunction or power failure etc from corrupted or formatted pen drive. Kingston pen drive files undelete utility easily restore data from various USB drive (flash drive, memory stick, jump drive, thumb drive, key drive) and many more USB drives. Thumb drive data restoration program provides reliable and secure method to recover all digital files format including midi, ppt, doc, pdf, mov, xls, jpg, gif, mp3, wav, exe, bmp etc. Software support pen drive in all capacities including 512MB, 1GB, 4GB, 8GB, 16GB, 32GB and even higher capacity drives. USB drive data backup utility support all leading brands like Kingmax, Samsung, Sony, Toshiba, Jet flash, Apacer, Lexar and many more. Software easily installs on all windows operating system such as Vista, 98, 2000, 2003, XP, ME, NT. The software development team of ddipr.com combines a variety of advance features in this particular software. Some of the important features are:
- Pen drive data salvage program recovers data even if Drive Not Formatted message is displayed on your computer.
- Software provides GUI interface which makes it easy to use and operate.
- Application supports all versions of windows like Vista, 98, 2000, 2003, XP, ME, NT.
- Software provides easy data recovery from logically crashed or inaccessible pen drive.
I am a company representative and fully satisfied with this application to restore deleted data from formatted or corrupted USB pe
Feb 16, 2010 | Kingston Technologies 512MB DataTraveler I...
Iam having 2 kingston pen drive of 32gb one of them is right protected and another one is problem when i store data in a folder it shows empty folder but memory is consumed and i want drivers to that pen...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 07, 2010 | Kingston 4GB Secure Digital High Capacity...
Move data from one computer to another with kingston 8gb data tra
When you plug in the Flash Drive to your old computer, it will show up in My Computer probably as Removable disk or "Kingston Data Travler". You want to open that link up and drag whatever files you need into that folder. After doing so you put the flash drive in your new computer and repeat the process except you drag the files out of the folder and onto your desktop or a folder of your liking.
Jan 31, 2009 | Kingston (SDCZ2-512-A10-KT)...
Kingston pen drive folder and zip folder not to see data
2) How to put Slax on CD:
http://www.fixya.com/support/r3879348-slax_guide_survival_live_linux_usb_flash
or
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 13, 2008 | Kingston Technologies 512MB DataTraveler I...
Reg Removable disk
or
Aug 01, 2008 | Kingston Data Express DE110, S21P104...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
