Question about Nokia 3120 Cellular Phone
How to format this unit ?? - Nokia 3120 Cellular Phone
  • Nokia Master
  • 17,130 Answers
You might have to visit the Nokia service to format and reinstall with the original software.
Why to format? Has the set hung up? or do you want to reset to factory settings, if so open phone setttings and reset on the window ' restore factory settings.'
Posted on Aug 28, 2010
Hi, I tried to install this Transcend micro sdhc 8 GB memory card. I would have read the installation instructions, but my bionic eyes couldn't read the stupid instructions. So I inserted it properly...
You can only format a microSD card when it is unmounted. Unmounting a microSD card-To unmount a microSD card, follow the instructions below: [Menu] >Settings&tools>Press Ok key >SD card & phone storage(card memory)>Unmount SD card Formatting a microSD card>[Menu]>Settings&Tools>SD card & phone storage(card memory)>Format SD card.
Aug 23, 2011 | Cell Phones
When the Camera is turned on it reads DCF Full Error. How can I fix this error?
.try to format both...
remove the sd card on your unit,then insert that to the mmc reader then format it to your pc,,after formatted.,,
open your unit without sd card,,go to menu - setting - format -reset
after that insert it to your unit.,then take atleast 15 shots.,.then turn it off.,.,then open again for you to find out if this procedure will okey.,
Feb 25, 2011 | Cameras
Our Samsung ES30 is showing a DCF Full Error. It is only 1 month old and has a 2gig SD card in it. What is the problem?
Feb 23, 2011 | Cameras
Rear Seat entertainment Volvo XC90
Hi
1) Make sure the discs you are using fit the correct format specified by your Unit . For example - if you are using DVD-R's that you have burned yourself and the unit does not support this format you will get this error.
2) Dirty laser lense causing the unit to have problems in reading the disk. Use a cleaning Disk like this one to see if the error resolves.
http://www.amazon.co.uk/Hama-DVD-Laser-Cleaning-Disc/dp/B00005UPDF
If the error remains and you feel confident to do so you can open the unit and look for the glass laser lense - usually blue in color under the DVD clamp. Use a cotton swab and some isopropyl alcohol to gently wipe the lens in order to clean it.
Allow to dry naturally for a couple of minutes before re-assembling the cover on the unit.
3) Try a CD in the unit - if the unit reads CDs and not DVDs - this is an indicator of a faulty or misaligned drive mechaninsm within the unit itself. In this case the drive unit will require service attention and need to be replaced.
Obviously you should check that any disks you are using are clean and free from scratches.
Hope this helps. Please do rate my answer. Many Thanks.
Aug 04, 2009 | Audiovox D1708ES Car DVD Player
Drum on model 1510 Kyocera copier
1-6-4 Image formation section
(1) Detaching and refitting the image formation unit
Follow the procedure below to replace or check the image formation unit.
Prucedure
1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit.
2. Remove the waste toner tank and toner container.
3. Remove the two screws holding the waste toner tank cover and then the cover.
4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation
unit.
Developing retainer
Image formation unit
Connector
Oct 28, 2008 | Kyocera KM-1510 Copier
HOW TO FORMAT NOKIA6060
you can only format your unit by using a device connected from your computer that has program for your unit, it's called twister that has a twister suite for nokia phones.
Sep 30, 2008 | Nokia 6060 Cellular Phone
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
Mar 19, 2008 | RCA OPAL M4001 MP3 Player
DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
FORMATING
step 1 - place disc into unit
step 2 - unit will recognize disc
step 3 - unit will state this disc needs to be formated press play/pause button
step 4 - it will ask you to confirm formating press "yes" play/pause
hope this helps. you can get you manual out and on page 47 it gives you these instructions
Jan 26, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Nokia 3120 Cellular Phone Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
