Question about HP Cameras
My HP photosmart E427 camera flash does not work. I have check the setting. Help please!
  • HP Master
  • 17,130 Answers
If here is no way that the flash is working even after you have tried the manual mode,it is possible that the flash unit is faulty in the camera.
it can be a pico fuse or even a line break but you will need to open. If the fault goes beyond this then you might need the assistance of the HP service as most of the spares cannot be got otherwise-- except passive componets.
Posted on Aug 28, 2010
When i want take a picture it alway says charhing the flash??? why to charching the flash??? please help me.... thanks you
Have you tried fresh batteries? If it has a rechargeable battery, try plugging it in to recharge over night. Also check your camera settings; red-eye reduction may decrease the power to make the make the photo or a constant auto-focus.
Feb 08, 2012 | HP Photosmart R927 Digital Camera
How do you turn the flash off on a hp photosmart 435 camera
Hi hookerglen.
NOTE The flash does not work while recording video clips.
To change the flash setting, press the Flash button on the top
of the camera until the desired setting appears on the Image
Display. The camera remains in the current flash setting until
you change it or turn off the camera.
please fellow the instructions in the picture bellow aid you use your hp cameras flash light better.
let me know if it works for you.
Thanks.
May 11, 2011 | Cameras
HP PHOTOSMART E427 CAMERA IT WORKS FINE WITH NO SD IN IT BUT WHEN I PUT ANY SD IN THE CAMERA IT SAY THAT IT DOES NOT HAVE THE RIGHT FORMAT... note, it gives me an option to format or cancel ive chosen...
1. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 2. Insert the card and again, go into the menu and do the format thing again. Do not stop to select one of the choices the camera has offered before. Go straight into the menu and format from there.
Sep 06, 2010 | HP Cameras
What does charging flash on photosmart m537 mean?
The flash gun needs to have a high charge available before it can flash - this can take a few seconds to charge fully ready to give off a full flash "flash" As batteries get older and uncharged - it takes longer to reach the correct charge on the flash
Hope that helps
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP Photosmart R707 Digital Camera
BROKEN lcd display
look up the model number on ebay and then find sub heading for parts- order part and install
May 13, 2009 | HP E427 Digital Camera
The card on my Photosmart HP E427 appears to be locked all of the sudden. I get a message that says "cards is locked" - What caused this and how do I unlock the card?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 17, 2009 | HP PhotoSmart M437 Digital Camera
HP photosmart E427 camera--No power!!!
dear,
if you are a technical person or can handle the electronics then open it from the screws and see if the cable or points that connects battery to the circuitry are broken or desoldered or unwired...
if you cannt handle it so dont try.. get it repaired by a technical person near u...
regards,
Oct 26, 2008 | Cameras
Help
charging flash means then the camera is charging the flash light,, thats not a problem,, just wait for a couple of min, , and then take photos,, hope i helped ya
Jul 05, 2008 | HP Photosmart R707 Digital Camera
Camera only dowloads half the pictures on memory card
I know some of my cameras have a 'on board memory' and chip. Most likly the desired pictures are there, or the memory card conection (in the camera) is not making a full connection. can you clean the contacts?
Apr 21, 2008 | HP Photosmart 635 Digital Camera
Memory card problem
use batteries with higher mah value prefereably above 2000 mah .use energizer or duracell
Sep 17, 2007 | HP E427 Digital Camera
Cameras Logo
51 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
