Question about Dishwashers
My Dishwasher starts but after 30 seconds it stops and the light flashers.It seems to make a noise as if it is been emptied.Any ideas? I have lost our manual. Thanks.
  • 17,129 Answers
Is it possible that the washer is not receiving the required water level to wash and the sensor is defective.?
Or is it possible that the drain pump or drain valve is faulty.
or the main controller is having a fault on program.
Try choosing a different program to see if there is any change.
Posted on Aug 28, 2010
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Shu3302uc/u12 will not pump out
It's most likely a seized pump impeller/motor bearings or a burnt-out pump motor. There are some simple tests for the pump that anyone can do:
A. If your washer is full of water:
1. Select a wash program and press start. You should hear a low humming noise. If you can't hear anything, you probably need a new pump, but try the next step before you start buying parts or call an engineer.
2. Open the door and pull the lower basket forward or lift it out completely. Find and lift the float (the plastic dome/mushroom in the bottom of the washer) all the way up. Keep the float lifted and the dishwasher should pump out. Stop if/when you hear a gurgling noise as this means it's empty and pumping mostly air.
B. If your washer is empty of water:
C: If you can hear the low humming noise but the pump doesn't start when you lift the float:
1. lift the float again for about 1-2 seconds then let it drop again for 1-2 seconds. Repeat this 10-20 times and see if the pump starts. The repeated stop/start signals to the pump motor can sometimes free a seized impeller.
If the pump does start, keep lifting and dropping the float switch (1-2 seconds each time) to see if the pump starts every time. If it does, you should be OK to use the washer, but further action is needed to stop the problem returning.
When you've done all this, post the results here and I'll advise you what to do to fix the problem or prevent it from returning.
Oct 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Homark dishwasher programs; ( Italian ?? )
just turn the timer around slowly and you will hear it start to drain
Dec 11, 2009 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Dishwasher Start Up Problem
seems like the temp is a little to hot is there a thermostat on there that can be adjusted?
Jul 04, 2008 | Dishwashers
Problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag mdb8600awq dishwasher drains good 20 seconds and stops
Dont know if you still have this problem, what I did was this - press the start button and keep going until you reach the number '2'. Leave it at '2' and in a couple of seconds it will start draining the rest of the water. Worked for me.
Feb 19, 2008 | Maytag 24 in. MDB8600AWS Jetclean II...
Dishwasher Problem -REVISED
Debris in the pump. Professional service required.
Jun 05, 2007 | KitchenAid KUDC02IRB Dishwasher
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
Owen Barnes
