Question about Bosch SHU9955UC Built-in Dishwasher
Bosch D/W model # SHU9955UC. Drain motor is running, but is not draining. Removed drain cover plate and all seems clear. Any thoughts?
  • scouch Aug 28, 2010
    Thanks for your very quicki reply, SilverDragon: Is there a quick and easy way to check for these blockages or do I have to pull the machine out to the garage and disassemble the whole thing?
  • scouch Aug 30, 2010
    Thanks to both SilverDragon and Macmarkus for your quick replies. Miracle of miracles: After visually checking the drain hose for kinks, I disconnected the dishwasher, hauled it out to the garage, "plugged" it in out there and lo and behold, the thing works fine.
    For future reference, I removed the left side panel and pulled off the drain hoses to check for blockages - found nothing.
    I then removed the drain cover plate, faked out the door switch, so I could observe the drain impeller function in acton, which appeared normal.
    I then dumped a gallon of water into the basin and ran the thing with the drain cover plate off just to see what would happen. I assumed it wouldn't drain, since I hadn't really done anything to it, but it proceeded to drain out onto my garage floor as I scrambled to get a bucket under it.
    Anyway, happy ending - just no explanation for it.
    Thanks again./Steve
  • Bosch Master
  • 2,605 Answers
Hi, Welcome to FixYa. It sounds like you may have a restriction in the drain hose. The other possibility is the pump itself. With Bosch units the pump can actually appear ok but in fact not moving the impeller. If you observe it after getting out the water you'll observe the motor running yet the impeller just sitting idle moving slightly back & forth. Let me know if you are able to service this further on your own and I'll explain to you how. Regards, Macmarkus :)
Posted on Aug 29, 2010
  • Mark MacDonald
    Mark MacDonald Aug 30, 2010
    Hope it all goes well. Glad to be helpful where possible.
    Keep us posted how it works when re-installed, careful to insure drain hose is elevated/looped before the home plumbing.
    Good luck.
    Macmarkus :)
  • Bosch Master
  • 12,061 Answers
Http://forum.appliancepartspros.com/attachments/dishwasher-repair/180d1207853064-bosch-dishwasher-troubleshoot-manual-bosch-dishwasher-troubleshoot.pdf
Hi please copy/paste the link above to get your troubleshooting manual, Now below is your exploded parts diagram, so you can see how it all goes and to be able to order parts.
http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=195132&&model_id=233039#d195132
Now it is most likely your Actual Pump that is blocked, or a Hose etc, check Both to see if there isn't something blocking the outlet or pump, and filters.
Also have a look at this post below, it explains things well.
http://forum.appliancepartspros.com/dishwasher-repair/8118-bosch-shu9955uc-12-drain-pump-running.html
Posted on Aug 28, 2010
Code d:08 bosch nexxt series 500
It is bound to be a blockage or the impeller is stalling due to foriegn objects like coins.
Mar 06, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Integra SHU 9955US/12 - when we start wash cycle, the detergent dispenses and the tub fills with water, but the wash cycle never starts (never spins spray bars). Seems like timer is counting down,...
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Jan 31, 2011 | Bosch SHU9955UC Built-in Dishwasher
Am trying to deal with source of non-draining problem-drains but not complteley. Have remove three screws from love plate but cannot seem now to remove the assembly (which also golds the lower spray...
If it is a Bosch, the following just worked for me: pull out screens and on left side of sump (looking down into bottom, 9:00 position) has a torx screw holding cover over drain pump, remove screw, cover has tab towards backside to lift towards you. glass is clear in water. and if no debris , spin impeller blades to see if jammed/frozen. if so, replace drain pump from front left side.
Oct 23, 2010 | Dishwashers
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Bosch dischwasher is not draining completely. I've taken out the mesh filter and the square plastic drain cover. Should I unbolt the white cover which I presume covers the drain? thanks!
I had the same problem, twice. Both times, the technician simply removed the drain hose and cleared it of a small food particle. Save yourself the service charge by unhooking the hose yourself, clearing it and rinsing your dishes THOROUGHLY before washing.
Feb 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch free standing dishwasher (can't find the model #) that doesn't drain the used water when finished. Are there any diagrams that I can access to check how to remove and check the drain?
just remove the screen from inside you will see a torx screw to the left side of the sump remove it. pull the protective cover of the drain pump impeller. once removed you can see if anything is in the drain. if the impeller seems fine you eithe have a bad drain pump or something is in your drain between the dishwasher and the sink clogged.
Dec 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hello, I have a Bosch SHU055A05UC dishwasher that does not drain. I've tried reseting the panel and clearing any clog that is close. Any thoughts?
maybe the drain motor has problem, check the wire first, unplug it and put it back again. see what's going on
Jul 06, 2008 | Bosch Dishwashers
Bosch SHU33A06/22 does not drain
I think so. Check for power at the pump. If so is it running. There are seperate pumps for drain and wash. It is also possible the impeller came loose and the motor is running but not turning the impeller.
Jul 02, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
309 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
