My backpack P 52 bought just 1 month back is damaged. Top handle which allows lifting luggage is damaged; I could not find any service centre in Cochin -Kerala My contact # is 9567899444 Email cecilaugustine@gmail.com
  • 17,130 Answers
Please check out the shops at Broadway, Ernakulam and Jos Jn,EKM .. there are many shops that have facility to get you handle replaced if you are not lucky to find the OEM to replace.
Just a tip.
Posted on Aug 28, 2010
  • Donald DCruz
    Donald DCruz Aug 28, 2010
    If you lodge a complaint with the dealership who sold the laptop, you will get a replacement for sure.
    Make a complaint to the call centre concerned .
    Just a help
I have sent a letter of complaint nearly two months ago now and I have not had a reply. My Husband bought a Samsung Mobile from Amazon and he had so many problems with it
for samsung mobile complaints under, u need to visit samsung service centre along with purchase bill, and then they will undertake repair/replacement as per problem with ur phone. subject to 2 conditions: its not water submerged and there is no physical damage already, both conditions wont be covered under warranty.
if u call samsung call centre, they will give u nearest service centre in your area, thats all call centre people can do.
u need to visit service centre
Apr 26, 2017 | Samsung Cell Phones
How do i take out bottom draw
Open the drawer.
Top tub : depress the right hand tub clip and push it back about 30mm. Repeat for the left hand side.
Bottom tub: remove the toe kick (refer section 9.4) and lower tub cowling (refer section 9.5), both optional.
1. If the cowling has not been removed, then the tub clips need to be pushed back about 130mm so the slide clears the cowling when the tub is lifted.
2. Lift the tub off the slides and push the runners back into the product.
3. Releasing the wire from the centre clip on the link assembly allows the tub to be moved further from the chassis (optional).
4. If the tub is being turned over for servicing, rotate it counter clockwise, remembering to remove the baskets first. Removing the handle will prevent it from being damaged.
5. Refit in reverse manner.
Oct 08, 2014 | Fisher and Paykel Dishwashers
Remove drawer from fisher-paykel dishwasher
Open the drawer.
Bottom tub:
May 09, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Dead mouse behind drawers. how do you remove drawers?
Open the drawer.
Bottom tub:
Aug 18, 2013 | Fisher and Paykel 23 in. DD603H SS...
Broken luggage handle fitting. How do I repair it? The handle is ok and the screw is expands along is still in the case but the plastic fitting that covers it has smashed off when lifting the case.
I think you will have to take it to a luggage repair shop. It may be costly. If the bag is old enough, replacing would be better,
Aug 08, 2013 | Home
Broken Luggage Stand
Get out the broken stand. Remove it with 2 wheels. You need screws with nuts and washers for each screw by 2. Or another 2 independent standings.
Jun 24, 2013 | Luggage & Travel
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
I need to replace the 3 button control panel which is one piece along the top of the draw many thanks wayne
Hi - this should help you out ..... enjoy.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub.
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this. Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side.
9.2.3 The tub may now be lifted up off the drawer runners.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Drawer and LCD Display Removal
9.3.1 Remove the drawer front as per instructions in 9.1.
9.3.2 The handle fits onto a lip at the top of the tub and then slides from left to right to lock into place. Push the right-hand end of the handle to the left until it feels free then remove it out towards you.
9.3.3 Disconnect the six wire harness from the electronic controller to the LCD interface.
9.3.4 The handle may now be lifted clear. The LCD display is held in place by a spring tab on one
end and a clip in the centre. Use a small blade screwdriver to carefully release the tab and centre clip as shown. The LCD assembly can now be removed.
9.3.5 The wiring harness can now be unplugged from the LCD.
9.3.6 Refit in reverse manner.
Jul 07, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Computers & Internet Logo
David Payne
David Payne
