Question about LG 42LB1DRA 42 in. LCD Television
No picture i turn on the tv and the standby button turns white and flashes for 5 seconds then goes to a constant white and thats when the picture should come up but it doesnt. It flashes on the screen then it goes black. Is there something wrong or is there a trick to fixing this problem?? I called LG customer service and they told me how to resolve the problem but it didnt work. It has slowly gotten worse the last 2 months sometimes it works and sometimes it doesnt, most of the time if i leave it on for a few days the picture will magically appear but lately i have nothing.
  • 58 Answers
Hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
Posted on Jun 16, 2008
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
I currently have my KV-27FS120 Sony TV connected to a cable box, which is receicing 100% signal. However, my television when powered on, the picture will tend to flash at times for a half a second and then...
Check whether the issue occurs with all the external devices like DVD Player, VCR, etc. If the issue is occurring with all the devices then the issue is with the TV.
Try these steps to check whether the issue is resolved.
1.Disconnect the power cable and connect it to a different working wall outlet.
2. Disconnect surge protector if you are using any.
3.Power reset the TV by turning it OFF for atleast one minute.
3. Reset the TV to the Factory defaults.
To reset the TV, turn it ON.
Press the RESET button on the Remote and press the POWER button on the TV at the same time. Now, TV will turn OFF and then back ON automatically.
Now, proceed with the Auto Program.
Check whether the issue is resolved after the Auto Program is finished.
All Sony TVs have a self-diagnose mechanism where the Standby light blinks to indicate that there is an internal malfunction in it.
Note: Your TV does not have the replacable LAMP.
If the issue persists TV requires service. Contact nearest Sony authorized repair center,
Jul 22, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
TV cycles on and off but never fully turns on
Tv POwers on shows a picture then picture goes and audio stays on
Apr 14, 2009 | Philips 43PP9202 43" Rear Projection...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
LG 42LB1DRA 42 in. LCD Television Logo
173 people viewed this question
Computer Repairing
Computer Repairing
